1. Guest,
Klipsch or Paradigm for HT
Discussion in 'Speakers' started by Brad Newton, Apr 6, 2003.
  1. Brad Newton
    Brad Newton Well-Known Member
    Aug 14, 2001
    387
    Listened to both today, Monitor 11 & (can't remember now if they RF3 or RC3). I thought Klipsch were too bright, but they didn't seem that way today, they just seemed more distinct. Sounded like you could hear the instruments more definable than the monitor 11. They will be used mostly for HT with some music, and probably paired with a Pioneer 45 in a fairly large room (25' x 15').
  2. Justin Ward
    Justin Ward Well-Known Member
    Jun 6, 2002
    673
    I have listened to Paradigm Monitor series and think they sound great. But if your ears prefer Klipsch, go with what sounds good to you.
  3. Justin Ward
    Jun 6, 2002
    673
    Another thing, I'm not sure what specific Klipsch models you are referring to but since they are generally efficient, you could use them in a large room more easily.
  4. Chris Elm
    Chris Elm Well-Known Member
    Mar 30, 2003
    120
    You are probably referring to the RF3 II, since the RC3 is a center channel:wink:
    Not sure what the rating on the Monitors are but the Klipsch are 8 ohms, which you will need if you have/are getting the Pioneer VSX-45tx (this has a hard time driving 4 or 6 ohm speakers).
    BTW, I have the RF3's and really like them, although bright at times.
    To each his own
  5. NicholasL
    NicholasL Well-Known Member
    Apr 3, 2003
    298
    I have that exact combination. The 45TX and 3 pairs of Klipsch RF-3 II's. Lemme tell you, it is literally true when people say you can play a cd, set it onto 7-D stereo (all speakers play equally loud), and you close your eyes...it truly feels as if there is somebody standing 10 feet in front of you singing.
  6. Brad Newton
    Aug 14, 2001
    387
    Chris,
    When do they seem "bright" to you? Listening to music, if so, what type? When I had listened to them previously, they did sound a tad bright, now I don't know if they were new & hadn't broken in (if that is required), because the ones I listened to yesterday had been on display for a while and they just seemed to have better separation than the Monitors.
  7. Chris Elm
    Mar 30, 2003
    120
    In my post, specifically I was thinking about Queen, in Another One Bites the Dust, where they have the special effects sounds, it gets overwhelming at times. The clarity is almost too good that it hurts my ears at higher listening levels. (I know... such a sad complaint to have).
    [​IMG]
    This is also due in part to what I had driving them until yesterday. It was an only audio system. It was an old Carver amp/Luxman preamp setup that was habitually on the brighter/harsher side as well.
    I am also shopping for a new receiver and was looking at the 45tx. Sounded very very good in the store.
    Cross-shopping a HK avr-525.
    BTW, I have never heard Paradigms, but from what I've read, excellent speaker as well. (deals to be had in Canada supposedly) unless you of course were talking about Monitor Audio (the brand)[​IMG]
  8. DanaA
    DanaA Well-Known Member
    Nov 21, 2001
    1,844
    Klipsch are highly sensitive to the audio gear they're matched with. Pair them with a bright receiver and they'll sound way too bright, at least to me. I've been hearing good things lately over at the Klipsch board about how Pioneers and Klipsch work well together. Haven't tested it out myself though.
  9. Tekara
    Tekara Well-Known Member
    Jan 8, 2003
    783
    I use the klipsch RF3-II's in my living room. . . I never did like treble much until I heard these speakers. it is very true that the horn tweeter on them is an acquired taste. but once your ears adjust to hearing such high frequencies everything else just seems to lack. . . "life". imho the klipsch speakers are quite good and do good justice to musical pieces that involve higher tones, flutes and piccolos in orchestral pieces all the way to the beeps, whines, and whirls in modern electronica.
    anyway, I love these speakers, I do agree that they can be bright at times (though combining them with the gernally considered "bright" sony da5es is surely to blame for this :p). If I ever get more speakers it will be along the same lines as klipsch if it weren't from klipsch themselves.
