1. Guest,
Is DTS dead on standard def DVD's?
Discussion in 'DVD' started by Chris Tedesco, Jan 3, 2009.
  1. Chris Tedesco
    Chris Tedesco Second Unit
    Aug 26, 2002
    421
    I might have missed this, but I'm just realizing that no new DVD's in the last several months carry the DTS audio format anymore. Was there a press release that DTS was only going to focus on HD DVD/Bluray?
  2. Bryan^H
    Bryan^H Producer
    Jul 3, 2005
    3,432
    551
    I'd say yes. 90% of new releases are Dolby Digital only.
    DTS is going strong on Blu-Ray though[​IMG]
  3. Chris S
    Chris S Screenwriter
    Apr 9, 2000
    2,537
    2
    Chris S
    It sure appears that way. I can't name a single DTS release from the past quarter which is typically the big release window when you'd think there would be quite a few. However like Bryan^H noted it's very prevalent on Blu-ray.
  4. David_B_K
    David_B_K Advanced Member
    Jun 13, 2006
    1,813
    314
    David
    although I almost always prefer DTS to DD, i do not really lament its loss on DVD. The bitrate of the picture is compromised IMO if they try to include both DTS and DD on a SD DVD (unless they spread the movie onto two discs, as in the LOTR special editions).
    However, as others have said, DTS is alive and well on Blu-Ray. Bitrate is not as much of a concern on a high storage format like Blu-Ray.
  5. Ernest
    Ernest Supporting Actor
    Dec 21, 1998
    635
    57
    DTS is very popular with the Asian and Region 2 STD DVD. To be honest I don't notice that much of a difference to make a purchase just because the DVD contains a DTS audio track.
  6. Frank@N
    Frank@N Screenwriter
    Sep 12, 2002
    1,718
    Every now and again, I'll encounter (and buy) an old SuperBit DVD for $5 or so.
    In doing so, I'm essentially creating a 'two-disc' set with the normal version for menus & extras and then the SB for higher bitrate PQ & DTS.
    I won't be buying BD, so for me this is as good as it gets for Sony movies.
