1. Guest,
inexpensive DVD player for DVD-A
Discussion in 'Playback Devices' started by Paul_Nyman, Apr 23, 2006.
  1. Paul_Nyman
    Paul_Nyman Well-Known Member
    Sep 20, 2002
    304
    I'm thinking about picking up titles on DVD-A while many are still out there.
    Can anyone recommend any low price name brands that playsback DVD-A?
    I have a Sony model DVDplayer which doesn't support DVD-A discs, but I can plug in for the amplifier and it has DTS decoder in it, it just won't play the media though hence the other player needed.
    Thank for any suggestions!
  2. Chris Gerhard
    Chris Gerhard Well-Known Member
    Nov 8, 2002
    1,279
    3
    Chris Gerhard
    I have the Samsung DVD-HD841 and JVC XV-SA600BK. The HD841 is a universal player that plays SACD as well. I paid about $50 each. Both are discontinued but may be obtainable, particularly the HD841.
    Chris
  3. MarkHastings
    MarkHastings Well-Known Member
    Jan 27, 2003
    12,013
  4. Matt Fisher
    Matt Fisher Well-Known Member
    Aug 4, 2004
    342
    I bought a JVC XV-SA75 a while back for like $60, plays DVD-A, works very well. I'd recommend finding a player that plays SACD also, you will probably find out pretty soon that SACD has a much larger catalog of titles.
  5. Mark-P
    Mark-P Well-Known Member
    Sep 26, 2005
    2,887
    786
    Camas, WA
    Mark Probst
    I own this one:
    http://www.amazon.com/gp/product/B00...lance&n=172282
    At $118 it's a bargain. You get a 5-disc changer, full dvd-audio decoding, dts, dolby digital and dolby prologic II decoding, 480p and a versatile zoom control for accomodating different aspect ratios.
  6. LanceJ
    LanceJ Well-Known Member
    Oct 26, 2002
    3,168
    Panasonic helped design the hardware for the dvd-audio format, so one of their players should be a safe bet. IIRC they also put together the original authoring i.e. disc creation software for the studios. So, except for a tiny smattering of negative reports the past 6 years, Panasonic's players never seem to have any problems playing any dvd-audio disc. Same goes for Pioneer's Elite series of players. But their entry-level DV-563 and later DV-578(?) are not so fortunate. [​IMG] But Pioneer's newest entry-level universal, the $130 DV-588, seems to be doing fine so far.
  7. LanceJ
    Oct 26, 2002
    3,168
    double post
  8. LanceJ
    Oct 26, 2002
    3,168
    FYI: a number of dvd-audio discs contain hi-res 48/24* and 96/24 stereo tracks that dvd-video players can play. This may be what is causing some confusion about how backwards compatible a dvd-audio disc can be. Most (all?) of DTS Entertainment's dvd-audios starting around 2003 are like this, a few early Warner titles, and all of AIX Records' discs (a hi-end label).
    If the packaging has the letters PCM or LPCM (linear PCM) written after the sampling rate/word length, then 99.9999999999999% chance it will play on a dvd-video player. But if the letters MLP (Meridian Lossless Packing) or PPCM (packed PCM) are there instead, you'll have to use a dvd-audio player to hear them.
    One exception....I think. Classic Records has been selling a format called an "HDAD". This uses a regular dvd flipper i.e. a two sided disc (it is NOT a DualDisc) to place a 96kHz/24bit stereo track on the dvd-video side, and a 192kHz/24bit stereo track on the dvd-audio side. I am *pretty* sure the 192/24 track is regular PCM, but since the dvd-video specification only allows up to the 96/24 PCM format, this won't play on a dvd-video player. Classic Records has an excellent reputation for very high quality remasterings, on both digital and vinyl formats. And they have done this for three Alan Parsons Project albums, one of my very favorite prog rock artists: I, Robot, Turn Of A Friendly Card and Eye In The Sky.
    BTW: their other/older "DAD" format is a regular one-sided dvd disc with stereo 96/24 on it.
    * many audio engineers consider the length of the sample word to be more important for *audibly* improved sound than the sampling frequency
  9. NickSo
    NickSo Well-Known Member
    Jul 2, 2000
    4,274
    They will work in a regular DVD player, but you will be getting the compressed Dolby Digital tracks, rather than the high rez lossless DVD-A tracks.
  10. Jack Briggs
    Jack Briggs Well-Known Member
    Jun 3, 1999
    16,740
    129
    Gentlemen, please discuss DVD-Audio players in the area designated for such discussion. The Music area is for talking about music and musicians themselves.
  11. Mark M. Smith
    Mark M. Smith Well-Known Member
    Oct 16, 2001
    56
    Not exactly. DTS releases may be more or less alone in this, but some feature DTS 96/24 recordings in 5.1. Having only a standard DVD player it sounds pretty good, but isn't quite up to what you'd get with a proper DVD-A player.
    As well (as was mentioned upthread) many DVD-A discs contain a compressed Dolby Digital 5.1 track basically treating it as a standard DVD, but without much in the way of picture information.
  12. Dave Moritz
    Dave Moritz Premium
    Jul 7, 2001
    4,626
    363
    Whittier, California
    Dave Moritz
    It depends on how much cash you are willing to spend. You can get a Denon DVD-1920: DVD-A/SACD Progressive Scan Universal DVD Player for around MSRP $369.00
    DVD-Video, DVD-Audio, Super Audio CD, Music/Video CD/CD-R/CD-RW Playback, DVD-R/RW Video, DVD+R/RW Video, Kodak Picture CD Compatible, Fujifilm Fujicolor CD Compatible, WMA9 Playback.
    DCDi™ by Faroudja Progressive Scan Decoding Engine, 10-bit, Dual, Discrete 12-bit, 216MHz Analog Devices Video DACs (480i/480p), WMA 9 (Audio only), MP3 Audio Decoder for CD-R/RW, DVD-R/RW Discs, Composite Video Output, Digital Bass Management for DVD-Audio/MLP/SACD, High (12dB) and Low Pass (24dB) with Speaker Configuration/Level Control and Delay Time Control.
  13. Dan Driscoll
    Dan Driscoll Well-Known Member
    Aug 1, 2000
    940
    2
    Paul, I sent you a PM.
  14. MandyHan
    MandyHan Well-Known Member
    Feb 28, 2006
    219
    That Denon player sounds nice, i just dont know if I want to invest in a format thats still not getting the support it should. How many years has SACD been on the market??5-6 years??
  15. MarkHastings
    Jan 27, 2003
    12,013
    Yeah that Denon does look sweet. HDMI output as well [​IMG]
  16. Emmett Maguire
    Emmett Maguire Well-Known Member
    May 13, 1999
    48
    I have the Pioneer 578 with firmware issues. It works great but won't play Talking Heads collection. In Canada you have to send the player accross the country to get it updated. I went and bought a 588 for 99.00 Canadian instead. It wqrks perfectly and gives me a backup player. These are also excellant for SACD considering their cost.
    Rgds
    Long live HiRez
  17. Dave Moritz
    Dave Moritz Premium
    Jul 7, 2001
    4,626
    363
    Dave Moritz
    The reason I recomended the Denon was along with a good quality dvd-a & sacd player. You get a good solid dvd player with an HDMI conection as well. Plus a great performing DCDi™ by Faroudja Progressive Scan Decoding Engine. For the money I honestly dont think you can beat the Denon. Yes there is not alot of dvd-s or sacd titles out on the market. But a really good player will give you better audio performance and you have a win win situation with the solid performing dvd player.
  18. Will_B
    Will_B Well-Known Member
    Mar 6, 2001
    4,733
    Toshiba SD-6980
    Ugly looking, but it does DVDA and SACD, and it's under $175.
  19. gene c
    gene c Well-Known Member
    Aug 5, 2003
    5,837
    46
    Bay area, Ca
    Gene
    You can get the 5 disc 6915 on-line for $80, if you can find one that works. Lots of problems when it first came out. But sounded great for the 1/2 hour that they worked! As for the Denon 1920, I have the 756 which is said to be the same as the 1920 and it saddens me to say the picture isn't near as good as my Yamaha 6770/750. Maybe I got a bad Denon or a really good Yamaha (if there are such a things), but I was very disappointed in the 756. Looked good on paper but... Should have returned it but waited too long so now I'm stuck with it. Don't mean to sound like a party pooper, but felt I had to say something.
