Rich Sk
Grip
- Nov 18, 2002
I'm in the process of finishing the basement, with a 7.1 system in the family room. To keep things neat, I plan on placing the components in an in-wall cabinet on the 'east' wall' of the room, the TV and front speakers on the 'south' wall, and the listening position will be facing the south wall. Because I have a hallway that leads off from the 'east' wall, you enter the room from the 'northeast' corner, and a fireplace sits diagonally in the 'southeast' corner, I'm assuming that the subwoofer won't be able to be placed near the cabinet because the east wall is pretty busy. I'm assuming that it will most likely sit across the room (15 feet) on the 'west' wall.
My question:
I plan on using the LFE output on my Denon 3803 receiver to supply the Deftech Super Cube and I'd like to keep the cabling behind walls as much as possible, but I'm not sure what to use for cable to go up the back of the cabinet, across the ceiling, down the west wall, and out a gang box. I bought a Monster Cable ultra subwoofer interconnect 1000 that is 25 feet long, but I doubt that it will be long enough to stick out of the wall and allow any flexibility in positioning the subwoofer. If I ignore that fact that it is not UL rated, can I run that cable across the ceiling, down the inside of a wall to a gang box, terminate it with some sort of female/female RCA face plate jack, and run another cable to the subwoofer from this jack?
Thanks for any input.
Rich Skordahl
My question:
Rich Skordahl
