1. Guest,
I'm going to get a DirecTivo, but some ?'s...
Discussion in 'Playback Devices' started by Tim Holyoke, Nov 19, 2003.
  1. Tim Holyoke
    Tim Holyoke Well-Known Member
    Nov 6, 2002
    268
    OK, I've decided I'm going to get a DirecTivo, but I have some questions. First, I have an old dish (w/just 2 cables running from it), and my local channels aren't coming until (they say) April '04. I'll need a multi-satellite system for the local channels - would that be included in the free installation? I remember reading another post that somebody called DTV and said they needed everything upgraded, and they put in a multi-sat. system for free. A majority of the things I'd record are on the local channels, so I'm thinking about waiting until the end of February (when the DTV Tivo offer ends) to get it. I live in Wisconsin though, so the ground will be frozen then, and our cables are buried and about 40' from the house (live in the country, trees in the way). I'm wondering if I should maybe open up the trench and lay a few more cables and just leave them be until Feb.?
    Here is the deal I refer to: http://www.directv.com/Email2003/Q42..._DVR_TiVo.html
    I didn't notice anything about it being only for new DTV customers? I'd get enough new receivers for 3 rooms, so if 2 cables went to the Tivo, I'd need 4 total (if I planned on using all 3 receivers)? I really like doing things myself, and would prefer not having the DTV guy come and do it all - is there any way to avoid having the DTV guy do it and still get the upgrades for free?
    Lotsa questions, I'm sure I'll have more [​IMG] . Thanks a lot.
  2. Kevin Stewart
    Kevin Stewart Well-Known Member
    Oct 7, 2003
    361
    Texas
    Kevin Stewart
    When you order these systems through Directv and they come with free installation, they will give you everything you need, including any multi-switches. However, Directv has been out of the directivo's for a couple of weeks now. If you follow the link you provided, I'm sure you'll find that eventually after trying to order it will tell you that they are out of stock. They may give you the option of submitting your Email address and they will tell you when they're available again, but I've heard that this may not be until sometime in the first part of 2004.
    Stew
  3. Robert_J
    Robert_J Well-Known Member
    Aug 22, 2000
    8,264
    46
    Mississippi
    If you want your installation done right, you might as well do it yourself. Go ahead and run two more cables out to the dish location. When locals are available, D* will upgrade your dish for free if you subscribe. Until then, go to Best Buy or Circuit City and get a $99 DirecTivo there since they are the only ones selling them to existing customers now.
    -Robert
  4. Kevin Nolan
    Kevin Nolan Well-Known Member
    Jun 16, 2000
    106
    If you find D* is out of stock try tiger.orbitsat.com. I am having mine installed tomorrow am with the triple LNB 18"x20" D* dish (ready for HDTV) for $119 delivered and installed. There are probably better deals out there but if Directv is out you can still have this system for probably less than what Direct wants.
