Charlie Campisi
- Aug 20, 2004
Vaughan -
You do realize that you calibrate using a test tone disc that sends pink noise (static hiss like) to each speaker and then you adjust with your receiver to equalize the levels, right? The following sentence gave me the impression you were planning on using a movie to calibrate.
Your receiver should have some test tones built in. You can try calibrating by ear using those. Later use the SPL meter (from your main seating position) to get a better read. Even better still, get Digital Video Essentials (subs in DVE should be set at +10 db compared to speakers) or Avia to calibrate.
Sorry if this is basic. Just wanted to make sure we were talking about the same thing.
As for bass demo discs, Incredibles (lots), Finding Nemo (Darla tapping on glass), FOTR cave troll and ROTK oliphants are all great.
Oh yeah, and the first place you should try your sub is in the front corner of the room, a couple of feet from the wall, in the corner of the room with the largest unbroken wall. And why is the sub on its side?
