1. Guest,
How to get digital surround sound from TV?
Discussion in 'Beginners, General Questions' started by Mukesh Singh, Sep 25, 2012.
  1. Mukesh Singh
    Mukesh Singh New Member
    Sep 25, 2012
    3
    I am having
    1- Sony Bravia BX32 TV,
    2- Philips HTS5520 home theater system and
    3- a normal set top box provided by local cable provider(DEN)(which has Loop out, Cable In, and Audio Video out(Yellow, Red, White) points at the back).
    How do I get digital surround sound from the TV programs?
    Please Help.
  2. Al.Anderson
    Al.Anderson Well-Known Member
    Jul 2, 2002
    2,464
    56
    Al
    The Bravia only has a digital coax input for surround sound, so you'll need a signal in that format. I'm not sure what "Loop out" is (a model# or picture would probably help); but otherwise your set top box looks like it doesn't have a coax output. The best case situation is that you can ask your cable company to give you a box with coax out and HDMI out. Then you'd connect the audio to the recevier and the HDMI to the TV.
  3. Jason Charlton
    Jason Charlton Ambassador
    May 16, 2002
    3,400
    316
    Baltimore, MD
    Jason Charlton
  4. Mukesh Singh
    Sep 25, 2012
    3
    Thanx Jason... I will try it.
