BruceD
- Apr 12, 1999
Earl,
I'm not sure I quite understand, you said,
I once had a similar setup to what you are thinking about and the main problem was getting the correct time alignment because the mains had to go through the second pre-amp and this caused a slight change in the sound stage.Are you implying that a 2-channel analog preamp is changing the time alignment of an analog signal to the main L&R speakers? I don't think so.
What makes you think that is the case?
It is certainly possible that the signal was frequency altered (distortion) by an analog preamp (especially tubes), but time alignment changes, nope.
