1. Guest,
Help with Yamaha RX-V671
Discussion in 'AV Receivers' started by Jceelica2197, Sep 10, 2012.
  1. Jceelica2197
    Jceelica2197 Member
    Aug 16, 2011
    5
    I have the Yamaha RX-V671 and I am having trouble increasing the sound of voices in movies. How do I increase the sound of the voices? the background music and sound effects are all louder than the voices, I tried all the different cinema DSP scene modes, and cant get the dialog to increase in movies. I am using a 5.1 setup and when i go into dialog lift it comes up grayed out.
    What can do?
    Thanks.
  2. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,041
    894
    Chicago-ish/NW Indiana
    Sam
    Dialog lift is a "height" mode(as in DPL IIz/Presence). (basically it is intended to create the "image" the voices are coming from the TV, not from under it in "typical center speaker arrangement")
    Is it that you can't understand the center at all...or is it really just that the volume is low?
    If the volume, you need to go into the level and raise the center. Or have you already done that...and it was no help?
  3. Jceelica2197
    Jceelica2197 Member
    Aug 16, 2011
    5
    The volume on the center channel is very low when watching movies. I didn't know I could raise the center channel, How do I do that?
  4. schan1269
    Jul 4, 2012
    17,041
    894
    Sam
    Go into speaker set-up...or run YPAO.
