1. Guest,
Help with Color Calibration..Please
Discussion in 'Displays' started by NealH, Apr 29, 2003.
  1. NealH
    NealH Member
    Mar 28, 2003
    24
    I am very new to RPTV..I just got a Hitachi SWX20B 51inch(I got an open box for $2400 with a 4yr C.C warranty)...
    I noticed a siginificant red push on the floor model..
    I have seen people recommend using an AVIA disc to color calibrate the screen..where do you get these..
    Also when setting up the screen for image quality etc...Do you do it for each mode 16:9, 4:3, cable TV, DVD, VCR use...
    I am a true novice and I am not sure how to proceed ..I wnat to reduce issue of burn-in and get the image quality I can..
    I realize Greg Loewen is an option too for ISF calibration..but I live Near Tampa and did not see him in this area
    What can you all recommend in order to "setup the RPTV" after first getting from image, burn=in standpoint..
    Thanks you very much and I am sorry if this has been asked but I have read a good portion of the burnin thread but I am very confused
  2. NealH
    NealH Member
    Mar 28, 2003
    24
    I guess this was in the wrong forum ..or I seemed to annoy with the topic..I am sorry...
    Can anybody direct me to good site on RPTV FAQ
  3. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Avia is available anywhere by special order ...
    Generally set the TV up for DVD first and see how everything else looks based on those settings. Make changes as needed.
    REduce burn in by never having contrast more than 50% and never use 4:3 mode.
    Recommend you let TV break in and then get professional calibration.
    Regards
  4. NealH
    NealH Member
    Mar 28, 2003
    24
    Michael TLV..thank you for the kind response...I will take your suggestions..also is AVIA disc available at a retail outlet?
  5. Thomas~Mur
    Thomas~Mur New Member
    Apr 11, 2003
    3
    Hi,
    I found my copy at Media Play "Pittsburgh", also if you are really hard up I know some Best Buys (please do not buy from them)have them. Avia direct might have a newer copy but i'm not sure of the differences.
    -Hope this helps.
  6. NealH
    NealH Member
    Mar 28, 2003
    24
    Thanks..is better to buy direct??
    Also how expense is an ISF calibration...several hundred $$$
  7. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    A basic ISF calibration has a suggested price of $275 ... but most people on these forums want more extensive calibration efforts. This tends to up the cost to about $400 to $600.
    Some get sticker shock over this, others do not.
    Regards
  8. NealH
    NealH Member
    Mar 28, 2003
    24
    thank you...yes there was abit of sticker price shock..although I expected the cost to be several hundred $$$
