Hi all:
Looking for some help. This set (rear projection) has performed flawlessly since purchased new in 2001. Came home today, turned it on, and convergence was WAY off in certain areas...so bad that the lower middle and lower left corner were not even adjustable, due to double images of the cross. In addition, the lower 1/3 or so of the screen image is..."curvy" for lack of technical words...and the images are overlayed in lavendar/green hues that I cant adjust. the upper right corner is slightly off, convergence wise, as well. But the lower 1/4 of the screen is not just a color issue, but a double image type of issue as well. Can barely read the cable screen menus. On the convergence screen....my problems are very evident on the Convergence 2 screen.
Crosshairs that are represented by the #3, #7, and #8 key are essentially double images now. For each of the crosshair #'s I mentioned, there are two crosshairs. One represented by one cross that is green and crooked. These green crosshairs are above the normal location of where these crosshairs are supposed to be.
The "normal" location of the #3, #7, and #8 crosshairs is occupied by a purple/pinkish version of the normally all white crosshair. For the most part, the remaining crosshairs (#1, #2, #4, #6, and #8) are ok, or at least I was able to correct their convergence.
Any suggestions as to what this might be? The TV has been working fine, hasn't been bumped, jarred, and is always connected to a high quality surge protector.
Any help is greatly appreciated.
P.S. The above problem is with any input..DVD, or cable.
Im guessing something has gone wrong with a lens? I have no idea, but I'm fairly handy with mild electronics. Is this a common issue? Something I can fix myself? Or is it time to call for a tech? If so, any recommendations for the Laurel, MD area for a tech?
