1. Guest,
Hellboy II Disc Problem
Discussion in 'DVD' started by CaseyL, Nov 16, 2008.
  1. CaseyL
    CaseyL Supporting Actor
    Jan 29, 2002
    803
    I recently got the SD Hellboy II Limited 3-disc edition, and I noticed that through the entire feature, there was a small green line on the right side of the screen. This is pretty apparent in really bright scenes (which there aren't many). If you skip to the chapter where they're in the mountains, when they meet the goblin creator of the golden army, it's really apparent. Could other owners of this film check their copies to see if it's a single disc issue, or if it's a press issue, please?
  2. Erin C
    Erin C Stunt Coordinator
    Apr 26, 2003
    168
    Finally watched my copy last night and didn't notice anything like that.
  3. Travis Brashear
    Travis Brashear Screenwriter
    Oct 31, 1999
    1,175
    Wonder if you need to bump the overscan on your TV up a tad to move that sliver of the image off from the viewable area of your screen...?
  4. Kevin EK
    Kevin EK Screenwriter
    May 9, 2003
    2,936
    446
    I didn't notice anything like this, but I'll check the disc again to be sure.
  5. StephenA
    StephenA Screenwriter
    Nov 30, 2001
    1,514
    I didn't notice it either when I watched my disc.
  6. CaseyL
    Jan 29, 2002
    803
    It's probably a problem with my disc copy then. I'll see about getting a replacement for it. Thanks
  7. Malcolm R
    Malcolm R Executive Producer
    Feb 8, 2002
    12,401
    466
    Vermont
    Malcolm
    Watched mine last night and didn't notice anything like that.
  8. Kevin EK
    May 9, 2003
    2,936
    446
    Finally got my review copy back to recheck for this error. No green line on the right side of the screen. Tested numerous scenes, including the exterior hillside stuff - got nothing. CaseyL, I think you're right - it's a problem with your copy. Try another copy on your equipment and see what happens...
  9. JPV555
    JPV555 Auditioning
    Jul 3, 2009
    I had this problem as well with a review copy I received. Universal then sent another, same issue (both 3-disc and single disc). Happened with my big TV and even on my computer monitor, no idea why and never found a solution.
  10. CaseyL
    Jan 29, 2002
    803
    I had the same experience. I got a replacement from Universal, but it had the same problem. I just gave up. I guess I'll upgrade to bluray, since that doesn't seem to have the problem
