1. Guest,
HDMI Switching Solution - Gefen??
Discussion in 'Playback Devices' started by MarkWC, Jul 26, 2008.
  1. MarkWC
    MarkWC Stunt Coordinator
    Jul 12, 2001
    159
    Hi all,
    I am looking for a simple hdmi switching solution. I have read the numerous reviews and will try to avoid Monoprice due to its lengthy problems with connectivity although very inexpensive.
    I live in Bermuda so it is basically a one shot deal; too expensive to return from here. I also noticed that there are not a lot of new posts on this subject or a mention of the Gefen Switcher that looks very feature based and a moderate price solution:
    Gefen Inc. - 4x1 Gefen tv Switcher
    Any ideas on how this one works?
    I have an non-HDMI Anthem AVM 30 so I need a switcher for:
    Tivo HD
    Xbox 360
    Panasonic BR
    Toshiba A3
    My display is only 720p but who prefer to get as much as I can for the $$ and the Gefen is 1.3 compliant for future upgrades.
    C
  2. PaulDA
    PaulDA Screenwriter
    Feb 9, 2004
    2,632
    48
    St. Hubert, Quebec, Canada
    Paul
    This is one you might consider: HDMI 4 in, one out switcher
    I have the 4 in, 2 out version: The 1 out version is 60$ and the 2 out version is 105$
    Mine works fine--I had a compatibility issue with a computer monitor (HDMI) but a DVI/HDMI adapter solved that issue--I plugged my HDMI cable into the adapter, plugged the adapter into the DVI input on the monitor, problem solved (and the issue was with my monitor, not the switchbox).
    Maybe the Gefen does something more (video processing, perhaps?) but I can say I'm happy with the one I got.
  3. CRyan
    CRyan Screenwriter
    Feb 9, 1999
    1,244
    Ok read that you dont want Monoprice. I have the new unit they sell and it works very well for me - even with two runs that are over 30'.
  4. CRyan
    CRyan Screenwriter
    Feb 9, 1999
    1,244
