Wayne Bundrick
- May 17, 1999
Wayne no one is saying that a caddy is easier to do but having one protects the surface of the disc much better than a thin layer of plastic. Personally I would find it horrible if Blu-ray ends up without a caddy because people complain that's it's to hard to use, even though most people have never even touched a Blu-ray caddy. Most people remember the ridiculous nature of early CD's in which you had to remove and replace the disc from the caddy. With Blu-ray you would never have to do that since you insert the caddy into the drive. The only reason you would remove the Blu-ray disc from the caddy is in case of damage to the caddy or if you were to put the disc into a mega-changer.Whoosh, my point flew right over your head. You're saying the caddy is good because the disc needs protection. I'm saying that disc shouldn't be so fragile that it needs that kind of protection. I'm saying that any new format needs to be more durable. I'm saying that if it needs kidglove handling then they should take that weak stuff back to the drawing board and don't come back until they have something that's built for the real world and not for a cleanroom. Not just Blu-Ray, but any future format that wants to offer more capacity and/or performance in a less durable form factor.
There is still no guarantee that HDTV will succeed. There are numerous industrial and political forces at work, some for and some against HDTV, and like the format that would be HD-DVD there is some serious greed coming from all directions. If HDTV is to be successful then it won't be without someone's house of cards collapsing first. And let's see how long Hollywood allows HDTV to continue to exist after HDTV ends up on the Internet despite all their efforts to stop it. Hey, I want HDTV to succeed as much as anyone else does, but HDTV is not what I see coming down the turnpike.
