getting into HTPC: audio formats? (1 Viewer)
EricW
i will be getting into HTPC with my next tv, and using it also as a monitor, so i'll be doing more PC games. my question is do most games use DD5.1 as surround? if not, will i need to get a new receiver to decode something else? i was hoping to simply connect the pc to my existing HT pioneer receiver to get 5.1 surround.
Darryl
The format of surround sound from your PC to your receiver depends on your sound card. The most common is to send it as analog signals that require a set of multi-channel analog inputs on your receiver. There are also some sound cards that do real-time encoding of surround sound to either Dolby Digital or DTS. Make sure you get a card that does real-time encoding, not just pass-through. The pass-through only works if the original source was DD or DTS, such as a movie. The digital pass-through doesn't work for games.
NHCondon
