1. Guest,
First projector! Help me choose?
Discussion in 'Beginners, General Questions' started by Lilly, Dec 17, 2012.
  1. Lilly
    Lilly New Member
    Dec 17, 2012
    4
    I have recently put an addition on my home to include a man cave. Part of this room will include a projection home theater. I am looking at the lower end, 720 models, trying not to break the bank.
    Any opinions on the Epson Power Lite 710 (model 710HD - V11H475020) or the Ben Q MW519?
    Any input is appreciated!
  2. Jim Mcc
    Jim Mcc Well-Known Member
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    It depends on your room and which projectors will work.
    1) What is your budget?
    2) What is your throw distance?
    3) What screen size do you want?
    4) How tall is your ceiling?
  3. Lilly
    Lilly New Member
    Dec 17, 2012
    4
    I have pretty much narrowed down the particulars in the two projectors I posted. I'd like to hang around the $700 and under mark for a pj.
    My throw distance is virtually unlimited, the room is 24' long.
    the screen will be approx. 90" diagonal.
    Ceiling is standard 8'
  4. Dave Upton
    Dave Upton Owner
    May 16, 2012
    2,331
    215
    Houston, TX
    Dave Upton
    What is your primary viewing use? Movies, games, TV?
    Also, are you okay with 720p?
  5. Lilly
    Lilly New Member
    Dec 17, 2012
    4
    720 is ok. This will be a simple application, not a high end installation. It will mostly be used for games, with a occasional movies and tv.
  6. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,041
    894
    Chicago-ish/NW Indiana
    Sam
    Are you setting it on a table and sitting behind it, or going to ceiling mount it?
    It does appear you have already done "some" research here as your screen size goal isn't overtly huge. Most PJ will do 90" from under 10 feet back.
  7. Lilly
    Lilly New Member
    Dec 17, 2012
    4
    ceiling mount, there is conduit and mounting blocks ready to accept any ceiling configuration.
  8. schan1269
    Jul 4, 2012
    17,041
    894
    Sam
    According to projector central, the Epson 710 will produce that image from 8'3"-9'11" and deal with 16% light/6 fc. Not too bad.
    The BenQ needs 9'4"-10'2" but at that size handles..62% light/23 fc.
    So the Epson lets you sit closer, if sitting it on a table in front of you, but the BenQ handles a lot more ambient light.
    Buy both and see which one you like best.
  9. schan1269
    Jul 4, 2012
    17,041
    894
    Sam
    Should have refreshed before adding more...
    Is the mount 10' from the wall?
  10. Jim Mcc
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Lilly, how did you come up with those 2 projectors? I think the Epson 710 would be WAY TOO bright for a 90" screen, even in low power mode. And the Benq 519 is a "classroom" projector, not designed for home theater.
    The best projector for your budget is the Benq W700. For a 90" diagonal screen, the lens would need to be mounted between 10'-1" to 11'-2" from screen.
  11. schan1269
    Jul 4, 2012
    17,041
    894
    Sam
    You think the 710 would be too bright?
    I was making my recommendation on "both" cause if this isn't a purposed room, they might need the BenQ to use a projector during the day. Of course, nighttime use they'd need sunglasses...
  12. Jim Mcc
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    No, I think it's going to be WAY TOO bright. PC lists it as having 55 foot lamberts with a 90" diagonal screen. Lilly said it's going to be a "man cave" and to me that means dark. Regardless, the Benq W700 is the best projector under $700 to fit the room.
