1. Guest,
DTS-HD Master Audio, DTS-HD High-Resolution Audio, Dolby TrueHD, Dolby Digital Plus
Discussion in 'Playback Devices' started by Gustavo Menendez, Oct 12, 2007.
  1. Gustavo Menendez
    Sep 13, 2006
    22
    I am, using a Panasonic DMP-BD10-A Blu-Ray DVD Player with an Integra DTC-9.8 Pre-Amplifier/Processor. The Integra (as well as the DVD player) has the codecs for DTS-HD Master Audio, DTS-HD High-Resolution Audio, Dolby TrueHD, Dolby Digital Plus Decoding; however the DVD player “bitstream” signal is not the “right” kind for the processor to switch to the “High Definition” codecs. I would like to see the correct codec identified by the processor.
    When can I expect a new firmware update that will permit the Panasonic DMP-BD10-A to pass the bitstream with the right format for the Pre-Amp/Processor to decode the new HD codecs? i.e., DTS-HD Master Audio, DTS-HD High-Resolution Audio, Dolby TrueHD, Dolby Digital Plus
    It is my understanding, tha there is only one Blu-Ray player on the market that is capable of doing that provided the firmware is updated!
    Anybody has any idea what can be done about these undisclosed issues?
  2. Adam Barratt
    Adam Barratt Well-Known Member
    Oct 16, 1998
    2,346
    Adam
    The Panasonic will never be able to output these advanced formats as bitstream, as this requires an HDMI 1.3 output, which it does not possess (HDMI 1.2 only). At best your player can internally decode Dolby TrueHD, Dolby Digital Plus and DTS-HD HR and output these as PCM via the HDMI port it is equipped with. Sound quality should be unaffected.
    DTS-HD MA is another matter, and internal decoding and PCM conversion in the future via firmware upgrade is unlikely.
    Adam
