1. Guest,
Do DLP, LCOS LCD, or any other fixed pixel display need ISF calibration?
Discussion in 'Displays' started by Jeff Adams, Nov 24, 2003.
  1. Jeff Adams
    Jeff Adams Well-Known Member
    Dec 13, 1999
    1,551
    I am in the market for a new hdtv and am leaning towards DLP or LCD and am wondering how easy set up is on these units. Do they need to be calibrated like CRT displays?
  2. JohnnyG
    JohnnyG Well-Known Member
    Dec 18, 2000
    1,523
    Perhaps there aren't as many things to 'fiddle' with, but these types of displays will benefit from accurate grey scale and a bit of tender loving care just as much as CRT based sets do.
  3. Neil Joseph
    Neil Joseph Well-Known Member
    Jan 16, 1998
    8,341
    Neil Joseph
    I had my LCD projector calibrated and the amount of time spent was a lot less than would be necessary for a crt, yes. The grayscale was adjusted as JohnnyG suggests.
  4. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Depending on the tech be it FPTV or RPTV tech ... you look to grayscale and colour decoder and some geometry items like overscan and centering.
    sometimes there are other things like edge enhancement circuits that need to be killed ...
    Faster ... but of course the pricing for such a service reflects the fact that less work is needed.
    Regards
  5. ChrisWiggles
    ChrisWiggles Well-Known Member
    Aug 19, 2002
    4,791
    Of course, every display will benefit with at least basic calibration. The extra setup that is involved with CRT is just that: setup. I wouldn't really consider it calibration. While it is paramount to have a good setup to get the most out of the display, it isn't directly a part of the more classical calibration items, like color temparature, greyscale tracking, etc etc.
  6. Ryan_McCormick
    Ryan_McCormick Active Member
    Jul 4, 2002
    42
    So it would be possible to have the overscan corrected on a Toshiba 62HM84 DLP via ISF calibration?
  7. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    Not really. Toshiba has taken a big step backward when it comes to calibration this year. You can only do grayscale and that is about it.
    Regards
  8. Mike Boniferro
    Mike Boniferro Well-Known Member
    Aug 21, 1999
    273
    Michael, have you had a chance to play with the HM85 sets yet? I know the 52" is available... I wonder if they 'corrected' this step back from last year?
  9. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    I haven't had a chance to play with one yet ... likely tomorrow night when I visit the store to play ...
    regards
  10. Ryan_McCormick
    Jul 4, 2002
    42
    Well that is definately not good news. Using the overscan screens on Avia and DVE it shows exactly 5% on all sides. Is that average? Should I be happy with that on a $3.5k set?
    I wouldnt really have put much thought into if DVE hadnt mentioned that DVD producers no longer compensate for the overscan and take important info and shots right out to the edges of the picture.
    Thanks for all your input on this guys.
  11. PerryD
    PerryD Well-Known Member
    Aug 28, 2000
    739
    I understand overscan on a analog setup, but why would there be overscan on a digital set? If the transmission is 1280x720 and the set is the same, the set should translate the image pixel for pixel, especially if the connection is DVI, correct? Otherwise, wouldn't there be scaling artifacts, scaling the 5% overscanned image up to the native resolution of the display?
  12. Ryan_McCormick
    Jul 4, 2002
    42
    I personally think that a 5% overscan on a higher end TV is a little much. Combine that with the fact that you cant correct it and it is unacceptable. Am I the only one who feels that way?
  13. PerryD
    Aug 28, 2000
    739
    On an analog set, 5% overscan was always the value to calibrate to, anything less and you may pick up flickering scan lines on the bottom of the screen from a few cable channels or from a VCR.
  14. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    5% is safe ... and when you are on an assembly line ... you use 5% ... because you don't have the time to dicker with units down to 2% say if some of the units can't do that ... for what ever reason.
    More time on the line means more money out of pocket.
    Regards
  15. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    "Michael, have you had a chance to play with the HM85 sets yet? I know the 52" is available... I wonder if they 'corrected' this step back from last year?"
    Greetings
    I was at A&B Sound last night and I finally got a chance to play with the new units. I calibrated the new 46" HM85 unit and before I started, I specifically looked for some of the more glaring problems that the 84 series had.
    Here are the highlights from the calibration.
    The Service menu is just as limited as before.
    Grayscale in Movie mode was 9500K ...
    The discoloration in the grayscale appeared to be pretty much gone. YES!!! They listened!!
    Grayscale tracking to D6500 was amazingly good ... almost ruler flat from 30% to 100% white with a slight dip to 7100 at 20%. This was very nice. Achieved in 5 minutes no less.
    From a pure image perspective, the new 85 series ... at least this one, was a very pleasant surprise and gets my tentative "thumbs up." It is better than the 44" Toshiba unit from the 84 line which was the best looking of that line.
    I won't be calling the new units my 75% sets ... they are my 85% sets.
    Regards
  16. Ryan_McCormick
    Jul 4, 2002
    42
    So if it is not correctable via ISF could a HTPC correct it for me? I have read that you can download programs to reduce overscan on HTPC's.
