1. Guest,
Difference between passive and powered subs?
Discussion in 'Speakers' started by Burki, Oct 5, 2003.
  1. Burki
    Burki Well-Known Member
    Aug 31, 2003
    45
    Any1 can explain the difference and usage plzzz?
  2. John Garcia
    John Garcia Well-Known Member
    Jun 24, 1999
    11,572
    23
    NorCal
    passive = does not have it's own amplification
    powered = just like it says
    With a passive sub, you either need to supply an external amp, or the sub will need to be run off of powered lines (speaker level vs preamp level out) from your receiver. The drawback to running directly off the receiver is that you will be drawing a significant amount of power to drive the sub in addition to your other speakers, which will reduce available headroom for all of your speakers. Another drawback is that you will not be able to use your receiver's bass management with this setup, as you will need to run your mains as large with the sub connected inline.
  3. Brian-Nu
    Brian-Nu Member
    Apr 27, 2003
    10
    John explained it pretty good [​IMG]
