1. Guest,
Denon menu screen while using DVE
Discussion in 'AV Receivers' started by AmusingistheDawn, Jan 14, 2009.
  1. AmusingistheDawn
    AmusingistheDawn Well-Known Member
    Nov 2, 2008
    155
    I would like to use the pink noise on the dve with my spl meter to set levels...but the only way to change the levels that I have figured out so far is to shoot to the menu screen (which uses the tv so you can't see the dve anymore...just the big black menu screen)...and adjustments of the channel levels can only be done when the internal test tones are going off. How are you supposed to use a meter with the DVE pink noise screen with Denon receivers?
  2. David Willow
    David Willow Babbling Idiot
    Jan 23, 2004
    2,246
    128
    Mechanicsburg, PA
    Dave
    Look at your remote - it may have buttons to do this. My Onkyo does.
    However, that is not why I'm responding... Why not use the internal tones? They are 75db (-30db) and will be more accurate than using a disc with Dolby or DTS.
  3. AmusingistheDawn
    Nov 2, 2008
    155
    Most people prefer to use the DVE pink noise from what I've read.
  4. David Willow
    Jan 23, 2004
    2,246
    128
    Mechanicsburg, PA
    Dave
    Then I disagree with "most people" [​IMG]
