1. Guest,
Damaging Receiver
Discussion in 'AV Receivers' started by BrendanG, Apr 28, 2003.
  1. BrendanG
    BrendanG Agent
    Feb 13, 2003
    27
    Somewhat of a strange question: I have all my components (receiver, dvd player, tv, cable box, subwoofer) plugged into the same surge protector. If i turn my receiver on first, am i doing any damage to my receiver by turning my tv or subwoofer of after that? is that sudden jolt of power out of the surge protector hurting my receiver? and another question, should i even have my subwoofer connected to the same surge protector or another outlet? is it too much power out of one surge protector? also i have a low end denon receiver and a 27 inch sony wega tv if that helps the answer at all. any answers? thanks
  2. BrendanG
    BrendanG Agent
    Feb 13, 2003
    27
    anyone?
  3. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    569
  4. BrendanG
    BrendanG Agent
    Feb 13, 2003
    27
    thank you very much
  5. Cagri
    Cagri Second Unit
    Dec 18, 2002
    415
  6. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    the general thinking is you don't want the potential for a transient from your preamp or whatever else is hooked up to an already powered up amp to be passed through your speakers giving them a thump. besides, it allows one to go through a ritualistic thing with their components. kind of like the Jo-Boo thing in "Major League".
  7. StephenL
    StephenL Second Unit
    Nov 21, 2000
    341
    For proper protection all interconnected components must be plugged into the same surge protector.
  8. Mark Barnhill
    Mark Barnhill Stunt Coordinator
    Jan 13, 2003
    87
    most definitely, power amps off first, and on last!
  9. Dave Milne
    Jul 2, 2001
    569
  10. StephenL
    Nov 21, 2000
    341
    A surge can cause a large difference of potential between components that are not plugged into the same surge protector. The difference in potential will equalize through any electrical connection between the components, possibly damaging them.
  11. Cagri
    Cagri Second Unit
    Dec 18, 2002
    415
    I was out for the weekend and I'd left all my components in standby mode. When I came back today, after about 60 hours, I saw that my receiver was on. Everything is connected to the same wall outlet without a surge protector. I thought the power might have been gone for a while and when back it could have turned itself on, but the timer on my VCR was working so that is not what happened. Everything was on standby still but the receiver, and it was very hot. It seems to work fine though... Can a surge cause such a thing?
  12. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Likely what happened is your power went on and off.
    This might be a good time to review or clarify what a surge is.
    Surge A surge, in the context of a surge suppressor, is a damned powerful punch. When a company markets a surge suppressor, and the unit is UL 1449 listed, they're talking about hitting that unit with a 6kV, 500 amp slug for 20 msec. What can cause something like that? Lighting hitting your outside service pole. Now that doesn't mean that a 200 amp slug isn't a surge. It is. But statistical analysis by the IEEE, a standards organization, has determined the 6kV one mentioned above as most typical.
    A surge protector can be constructed in many ways. Depending upon how they're constructed, the amount of voltage they let through in the event of a surge is typically 330 volts I believe. Less is certainly possible and it really depends how the manufacturer has chosen their components. It also depends on what specifically is being protected as to what the let through voltages will be. Satellite and cable have more stringent requirements and if you take a look at Panamax's products you'll see what their let through voltages are.
    I don't know if you've got your own house. If you do, I strongly advise that you have a whole house unit installed by an electrician or yourself, if you happen to be comfortable working around electricity. Then you can always choose secondary devices to handle things like glitches, spikes, noise, etc.
  13. Cagri
    Cagri Second Unit
    Dec 18, 2002
    415
    Thanks Chu.
    I am doing some reading to determine if I need the use of a surge protector. I see different types of surge protectors some of which are presented as "computer protectors", others as "A/V surge protectors". Is there a difference between them other than the telephone line connections or can you use one for everything?
  14. RobCar
    RobCar Stunt Coordinator
    Nov 27, 2002
    201
  15. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    good thing it wasn't Poltergeist!
    If, for whatever reason, you're going to opt for a point of use system and not whole house (which i strongly advocate for), then everything that's connected in your HT system needs to be protected. Posts along these lines have been many both here and in Tweaks.
    A very inexpensive and apparently capable unit is one from Stratitec that protects cable, and other equipment. It's a little over 3000 joules (MOV based) and you can get their top of the line for under $20 at Sam's Club. The Max series from Panamax is not too shabby either but the prices are higher.
    Other types of units, that go away from MOV technology is the DPS series from www.transtector.com. While also protecting against surges, they also do a very nice job with noise and glitches. You have to buy those direct from the company. A little under $100. Transtector is a sister company of PolyPhaser, one of the industries giants when it comes to lightning protection.
