Ron_S
Grip
- Apr 29, 2004
I'm getting ready to connect my components and have a few questions regarding what connections to use.
Here is my equipment at this point:
Denon 3805
Humax DRT-800 Tivo
Infocus X1
Xbox
7.1 Totem Mite setup
Klipsch RSW-10
For audio hookup between the Humax and Denon, is it correct to assume I need to use the digital optical connections to get better than 5.1 surround? The Humax will serve as my primary DVD player.
I'm planning on using the Humax as my tuner (I only have analog cable right now) for the X1 so I installed the component to VGA cable which I was planning on connecting to the Denon then going from the Denon to the Humax. Am I on the right track there?
I will be connecting my Xbox into the Denon via S-video and L/R audio connectors.
Thats pretty much where I'm at, what do you think?
Ron
Denon 3805
Humax DRT-800 Tivo
Infocus X1
Xbox
Klipsch RSW-10
Ron
