1. Guest,
cleaning dust off equipment
Discussion in 'Beginners, General Questions' started by james st. james, Apr 3, 2002.
  1. james st. james
    james st. james Auditioning
    Jan 13, 2002
    7
    i have a black entertainment center, speakers, and components that seem to suck up all the dust in a three mile radius. what is the best way to clean dust of equipment, tv screens, and whatnot? are the usual things like pledge safe for electronic equipment?
    thanks.
  2. jeff cr
    jeff cr Agent
    Mar 2, 2002
    49
    i wouldn't use anything on the components themselves other than vacuuming them of. i have a small dustbuster that i use for the components and the tv screen i use windex. you could use pledge on the cabinet itself but make sure not to get it on the components.
  3. Jack Briggs
    Jun 3, 1999
    16,740
    129
    Use a small vacuum-cleaner attachment with brush-like ends. As for the TV screen, you might want to avoid amonia-based glass cleaners such as Windex. Why not go to an optomerist's office and see if you can purchase a non-amonia-based spray cleaner intended for protective-coated eye glasses? Failing that, use a very mild detergent mixed with water. Apply the spray or detergent solution to the cloth, and wipe the screen in vertical motions (very gently). Use the softest-possible cloth.
  4. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,399
    i also wouldn't use pledge-type products on the equipment. it tends to leave a "greasy" feel.
    obviously, don't spray whatever cleansing product directly on the components...especially if it has vents!
    i usually just use a soft cloth...no cleaning stuff on it. when i'm really motivated, i'll even bust out a q-tip to clean the nook and crannies!
  5. Jeff Pryor
    Jeff Pryor Supporting Actor
    Mar 5, 2002
    654
    I use Pledge Grab-Its. No greasy residue that I can feel. These are perfect for any kind of stereo equipment and actually pick up the dust instead of just spreading it around. I use this on my TV screen as well as normal ol' Windex. Been using these products for years and my system looks brand new.
  6. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    423
    arent those grabits based on static electricity? i probably wouldnt want to put those near electrical equipment. its probably only a slight risk, but its undue risk none the less...
  7. Jeff Pryor
    Mar 5, 2002
    654
    No risk at all. They don't work by static electricity, but by being treated with a small amount of Pledge.
  8. Mr. Brian
    Mr. Brian Stunt Coordinator
    Nov 12, 2000
    59
    I use a Chamois cloth, the kind that's usually used for cars. Just get a little section of it wet with water and use it to clean all the equipment. It's perfect for TV screens as well. All the dust will come up and no smudges or streaks.
    Brian
  9. Max Knight
    Max Knight Supporting Actor
    May 8, 2000
    535
    I've found a lambswool duster to be very effective.
  10. james st. james
    Jan 13, 2002
    7
    thanks for the advice
    ~james
  11. Robley
    Robley Extra
    Mar 17, 2002
    16
    I use Endust for Electronics. I have a can in computer room
    and a can by h.t. stuff.works good on t.v screen as well as
    cabinet and receiver.
  12. Luis A
    Luis A Second Unit
    Aug 2, 2001
    417
    I use Billy Bags audio duster every morning before I turn my equipment on. The duster doesn't just "spread" the dust around, it attracts it like a magnet.
  13. Jon_Welker
    Jon_Welker Second Unit
    Apr 29, 2003
    404
    Similar concept here is the Swiffer Duster. These things are a God send. They pick the dust up and can be used in between components and the rack. They are outstanding.
  14. Garrett Lundy
    Garrett Lundy Producer
    Mar 5, 2002
    3,764
    California dash duster.
  15. Shervin
    Shervin Agent
    Jul 24, 2003
    31
    I have had pretty good results with pledge for electronics, but it ishard to find. I use the air duster in a can often. It is very easy to get the crud out of tight spots.
