1. Guest,
Christmas LED Lights Out?
Discussion in 'After Hours Lounge (Off Topic)' started by Johnny Angell, Dec 2, 2013.
  1. Johnny Angell
    Johnny Angell Played With Dinosaurs Member
    Dec 13, 1998
    5,775
    508
    Central Arkansas
    Johnny Angell
    Discovered two strings with a bunch, but not all lights, out. Did a little online research. Could be a fuse problem. I had to go online just to figure out how to open up the door on the plug. Replaced the fuses. Didn't fix the problem. I'm wondering if the fuses have a specific direction they go in? The damn things are small and it's difficult to tell.
    Then I find some info that indicates if one led goes out, all the bulbs in that circuit (there are usually two) go out. This is news to me as I had thought that if one bulb was bad, the others would still work. Guess not.
  2. Malcolm R
    Malcolm R Well-Known Member
    Feb 8, 2002
    12,389
    460
    Vermont
    Malcolm
    I think if it was a fuse issue, all your lights would be out. When only one section is out, it's usually a bulb or wiring issue.
    I'm not an expert on LED lights, but I assume they have many of the same issues as regular incandescent Christmas lights. Do you have a spare bulb? If it's a bulb issue, you might need to go bulb-by-bulb through the section that's off to try and find the bad bulb.
  3. BrianW
    BrianW Well-Known Member
    Jan 30, 1999
    2,562
    28
    Brian
    Most LED light strings are in series in order to maximize the voltage drop so as to minimize the current needed to light all the bulbs. So, yeah, when one goes out, the rest in the circuit do, too. If the bulbs are replaceable, go bulb-by-bulb until you find the bad one.
    Stan likes this.
  4. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,037
    894
    Chicago-ish/NW Indiana
    Sam
    A batch of these were on sale a few weeks ago. To check the wiring I plugged one in and pulled a bulb. When 15 went out...it went back on the shelf.
  5. Stan
    Stan Premium
    May 18, 1999
    2,504
    152
    Thank you "Sheldon". Speak in English next time (just kidding).
    We're not all electrical engineers, most of us are just regular nerds.
    BrianW likes this.
  6. jamestella
    jamestella New User
    Dec 28, 2013
    jamestella
    LED lights rae important part of our life as some ofthe images that Ima showing from web guide how imortant they are as that is why they are called the Best Energy Saving Lights
    Let Get How more important they are as help toimprove our living ability ,,,....Havelook these images..
    [​IMG]
    [​IMG]
    [​IMG]
    A beautiful Gift is always part of special ocassion that remembers always try to give a tree on such ocassion to make our environment more eco-friendly
  7. Northgun
    Northgun Well-Known Member
    Aug 27, 2013
    292
    34
    Jacob
    I haven't had much luck with LED Christmas lights, I;ve lost every set I've owned. The ambient lighting for my home theater is LED and haven't had any issues there. Not quite sure why I have the issues with the Christmas lights
  8. Edwin-S
    Edwin-S Well-Known Member
    Aug 20, 2000
    5,927
    273
    Most likely due to the harsher environment that the lights operate in. An electrician friend of mine bought a bunch of the things. When they quit working after a year or two, he just threw them out and went back to regular incandescent bulbs. The hassle of trying to find a burned out LED in a series wired string wasn't worth the trouble of finding it.
  9. Northgun
    Aug 27, 2013
    292
    34
    Jacob
    That makes sense. I'm probably going to stick away from LED Christmas lights for outdoors for now
