1. Guest,
cheap subwoofer amplifier
Discussion in 'Home Theater Projects' started by Oachalon, Sep 21, 2005.
  1. Oachalon
    Oachalon Well-Known Member
    Apr 23, 2002
    196
    Alright i am going to be running dual Adire Audio tempests and im looking for a cheap amp. My choices are to run the subs wired together which will give me either a 2ohm load or an 8ohm load. The other choice is to get an amp that will do 250x2 at 4 ohms. I wanna run 250 watts to each sub. So a 250x2 at 4 ohm amplifier or an amp that will do 500watts at 2ohms or an amplifier that will run 500 watts at 8ohms. Trying to keep it cheap as possible.
    Thanks.
  2. Ryan Schnacke
    Ryan Schnacke Well-Known Member
    Feb 5, 2001
    877
    Cheapest option is probably the Nady XA900 from www.musiciansfriend.com
    300W x 2 channels at 4 ohms for $180 plus shipping. But this is a fan cooled pro-amp so you'll have to decide if fan noise is going to be a problem for you.
  3. Oachalon
    Apr 23, 2002
    196
    I dont care about the fan noise. So this amp will work fine for the subs?
  4. Mark gas
    Mark gas Well-Known Member
    Mar 23, 2002
    322
    Yes it will.
  5. Oachalon
    Apr 23, 2002
    196
    anyone know where i can get rca to xlr connectors then cheap. Since it looks like this amp only has xlr inputs.
  6. Oachalon
    Apr 23, 2002
    196
    would you guys go with that nady amp or would you go with 2 Rythmik Audio A250 Basic amps. I would have a Rythmic for each tempest.
  7. Andrew Pratt
    Andrew Pratt Well-Known Member
    Dec 8, 1998
    3,813
    The Nady would get my vote and you can get adapters for XLR to RCA at radio shack. You might find that you can unplug the fan on the amp altogether as it still likely won't be run as hard as they are designed to. My QSC has been running without a fan for awhile now. It gets pretty warm but hasn't shut down at all.
  8. JimPeitersen
    JimPeitersen Well-Known Member
    Dec 7, 2001
    474
    Just a point about the fan noise, you may think it won't bother you but I can almost guarantee that it will. If the amp is in your listening room, you will more than likely find it objectionable over time. If it is in another room, then the point is moot. And, yes the amp will work perfectly for your sub(s).
    JP
  9. Ryan Schnacke
    Feb 5, 2001
    877
    At $40 extra, the Rythmik amps are a reasonable alternative. They give you fan-less cooling, rumble filter, adjustable phase control, adjustable low-pass filter and a integrated solution (amp is built right into the subwoofer enclosure).
    The Nady amp gives you stability down to 2ohm loads (stereo) to get more power plus the ability to bridge both channels to get very high power into a single load, at a price that's $40 cheaper.
    I'd say its a personal decision that depends on how tight your budget is, whether you can tolerate fans and what future projects the amp might be used for ... cause lets face it, DIYers are suckers for an upgrade.
  10. Oachalon
    Apr 23, 2002
    196
    how much louder is the fan on that amp compared to a normal computer and the projector that are both in the room. The amplifier is probably going to be about 14 feet from the listening area so im taking a guess i wont be able to hear it from that far. Right now i am pushing towards the nady amp.
    Also will these work fine for that amplifier going from rca to the 1/4" plug.
    http://www.partsexpress.com/pe/pshow...90-285&scqty=2
  11. Patrick D
    Patrick D Well-Known Member
    Jun 13, 2001
    65
    Oddly, the XA-2100 is quieter than the XA-900. I had to fan-mod the XA-900 (two 23db computer fans), but I left the 2100 alone. It sits right in my stack not more than 6ft away.
    Noise on the 900 was something like 50db from 1 ft away, or like a louder computer (not the crazy overclocked with five blowholes kind, but not the newer "big fan/slow RPM" stuff either). The fan mod didn't help a huge deal, as most of the noise seems to come from the case resonating with the fan vibrations.
    Anyway... you don't need to go RCA->XLR, I use RCA->1/4" mono plugs... they're easier to find and easier to use, IMO.
