1. Guest,
Cheap Garage to Home Theater Conversion
Discussion in 'Home Theater Projects' started by Swanny, Mar 5, 2009.
  1. Swanny
    Swanny Active Member
    Nov 25, 2008
    30
    Attachment 1322
    I converted my garage, a totally under utilized space into a Home Theater for under $10,000.
    Attachment 1323
    The garage door was replaced with glass sliders that match the house.
    Attachment 1324
    Screen measures 120" diagonal
    Attachment 1325
    Curtains hide storage.
    Attachment 1326
    I purchased black out curtains from Target and had my local tailor hem to fit.
    This is where I film The Home Theater Show
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. Kevin Stewart
    Kevin Stewart Well-Known Member
    Oct 7, 2003
    361
    Texas
    Kevin Stewart
    Looks nice.
    Only things I would have done differently is spread the L/R speakers out a bit more (depending on your seating distance), lower the screen and L/R speakers (both seem to be about 5' high, as opposed to head height ~ 3'), locate the equipment so it's not in view when watching (lights can be a distraction) and paint the trim, ceiling, and front wall black to reduce reflections.
    How far back is the seating? Riser? Are the towers used for 2 channel?
  3. Swanny
    Nov 25, 2008
    30
    Kevin,
    Good points...Will be painting the ceiling black as soon as I get some time. The towers are new and yes I do use them for 2 channel. My next project is to move the 2 front in wall speakers to the sides of the room to make my system 7.1 compatible. Row of seating is 10" from the screen. I do not have risers.
  4. Jim Mcc
    Jim Mcc Well-Known Member
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Nice job. I would highly recommend painting the screen wall flat black.
  5. serraniruben
    serraniruben Member
    Mar 7, 2009
    13
    Hi all,
    Good job,
    Really a full improved space.
    I only change the color on the screen wall for a more darker one.
    Only my two cnts
    Rub{en
  6. mrpaseo
    mrpaseo Active Member
    Jan 17, 2009
    41
    Very nice clean look, I like it. Thanks for sharing.
