wally
- Feb 12, 2001
Although I have no experience with them, I’d shy away from the hybrid charcoal/gas grills. Hybrid products generally don’t do anything well.
I had no idea that this would be such a hot topic.
I refuse to be grilled on this issue.
Stick a fork in me. I'm done.
I agree with the previous response to this...
*groan*
That's why gas-fired infrared grills has started to become popular. The reason is simple: because of the very high temperature of the infrared heating element, you get meats cooked just like what you get from a charcoal grill but without the long startup times and cleanup issues of charcoal grills.Todd H said:Taste the meat, not the heat. Gas all the way.
Hello everyoneTodd H said:Taste the meat, not the heat. Gas all the way.
I've used Charcoal for quite a few years and just recently went with a Gas Grill ( Propane) and after using one of these smoker boxes,I must say that it does add alittle more to the Flavor of the meat(s) being cooked. I don't do 13-15 lb Chunks of meat , so this works for me:Blu said:If you really must have that smokey flavor then get a smoking tin or foil, throw in your wet woodchips and set above the gas burner. You'll probably not be able to tell the difference in a blind taste test.
However, this may be changing very soon. When TEC lost the patent rights for infrared grills a few years ago a number of companies started to make this type of grill, where you have gas-fired ceramic burners where the infrared heat from the ceramic element heats the food. The advantages over both conventional gas grills and charcoal grills are obvious: 1) high-temperature, evenly-consistent heat (no "hot and cold spots" that are the bane of charcoal grills and because the heat from an infrared grill element is much higher than even charcoal the food cooks very rapidly, sealing the juices of th meat) and 2) you have the startup speed and cleanup convenience of gas grills (why wait 30 minutes to heat up a charcoal grill and deal with the ash cleanup afterwards?).Dan_N said:When debating Propane over a nature wood or charcoal fire, keep in mind, not one single person or BBQ team has ever won a major BBQ contest using a Propane fired grill?
