1. Guest,
Ceiling Mount for Onkyo-S5500?
Discussion in 'Beginners, General Questions' started by kismetgeek, May 7, 2013.
  1. kismetgeek
    kismetgeek Member
    Apr 4, 2013
    8
    nixmix
    I purchased the Onkyo S5500 based off the recommendations from these forums and the system looks impressive.
    What type of wall brackets should I use for the 4 satellite speakers? I've never mounted speakers before, so I want to make sure that I purchase the correct type.
    -Thanks
  2. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,037
    894
    Chicago-ish/NW Indiana
    Sam
    It would help us, help you. If you posted a picture of the backside of the speakers. I've never seen them to even know if they have any form of provision for a mount.
  3. kismetgeek
    kismetgeek Member
    Apr 4, 2013
    8
    nixmix
  4. kismetgeek
    kismetgeek Member
    Apr 4, 2013
    8
    nixmix
    This is the back.
  5. gene c
    gene c Well-Known Member
    Aug 5, 2003
    5,837
    46
    Bay area, Ca
    Gene
    You just need a pan-head screw. That's the kind with a larger head than normal. Just make sure it fits through the whole in the little bracket. If there isn't a stud where you want to mount them then also get a drywall anchor like one of these.
    http://www.diylife.com/2010/12/01/best-wall-anchors/
    I would also put a couple of rubber bumper things near the bottom to keep the wood from scraping the wall.
    http://www.amazon.com/Waxman-4215395N-2-Inch-Heavy-Bumper/dp/B001WAK6DS/ref=pd_sim_ac_7
    Both are available at any hardware store.
