1. Guest,
Can't read from CD-ROM, please help!
Discussion in 'Computers' started by Bob Movies, Jan 1, 2005.
  1. Bob Movies
    Bob Movies Well-Known Member
    Oct 15, 2000
    205
    Hi everyone,
    I burned a backup copy of all my documents to a CD yesterday. I even burned two copies of the disc, in case there was some sort of burning error that wasn't reported.
    Now, I've reformatted my computer, reinstalled Windows XP, and I can't read from the CD. About 75% of the files work with no problem, but when I try to copy the other files to my computer I get the error "cannot read from source file or disc". It seems to be happening on certain specific folders.
    When I try to copy the files using the command prompt, I get the error "the parameter is incorrect" and the files won't copy.
    The only problem I can think of is that the disc was burned as a multisession disc (with the option of not writing any additional sessions) using Easy CD Creator 5.
    Could this burning method somehow lock out files?
    I've tried burning a copy of the disc, and using the copy, but it still didn't work.
    I tried capturing the disc to an image on the hard drive and mounting it with a virtual drive program, but I still get the same error.
    Any help, or a suggestion for a recovery program (or a program that would allow me to read these files) would be appreciated! My current drive is NTFS, and I'm using windows XP.
    Bob
  2. DaveNel
    DaveNel Well-Known Member
    Oct 13, 2004
    447
    Are you putting the CD back in the burner drive, In some cases a Burnt CD wont work in any other drive but a CD Burner.
  3. Christian Behrens
    Christian Behrens Well-Known Member
    Mar 2, 2000
    714
    SF Bay Area
    Christian Behrens
    ISOBuster might be of help here.
    -Christian
