KeithH
- Mar 28, 2000
Kevin, the 'JA555ES does not offer MDLP, while the 'JA333ES does. That's a feature that I really don't need, though if I had it, I'd probably play around with it out of curiosity.
I appreciate your pointing the differences between the 'JA333ES and the 'JA555ES. I have not researched the 'JA333ES too closely and was not aware that the 'JA333ES has just one power supply. You have me curious as to how big a difference there is between the sound quality of the two players using the analog outputs, which is how I used the 'JA555ES. Hmmm....
Regarding the Sony pro decks, according to Sony's web site, the MDS-E10 and 'E12 use ATRAC Type-R, offer MDLP, have a PC keyboard input, and sport 24-bit A/D and D/A converters. A couple key differences between the two models is that the 'E12 adds balanced outputs and an RS-232 input. Also, the 'E10 has both coaxial and optical digital inputs and outputs, while the 'E12 has coaxial inputs and outputs only.
I went to a Sam Ash store today, and unfortunately, they had no pro MD decks on display. They had the Sony 'E10 in the back, but I was not going to have them take one out of a box since I was not going to buy one. Besides, they were selling it for $459, while Oade Bros. quoted me $425 for it. They didn't have the Tascam unit either, though they can get it. Interestingly, they quoted me $399 for it, which beats Oade Bros. quote of $415.
Based on what I have read about the pro decks having more robust transports than consumer decks, I am definitely intrigued by the pro decks. However, the fact that the Sony pro models only weigh 6.5 lbs. concerns me. Even the Sony MDS-JE470, which is a $180 entry-level consumer model, weighs more. Of course, weight does not in and of itself translate to quality sound. It should be noted that no musician or recording engineer, whom pro decks are designed for, want a 33-lb. or 24-lb. MD deck. Given that they transport such components from one venue to another constantly, weight is likely to be a major issue. So, the lighter, the better. Rack mounting heavy components would probably be a pain as well. I'm sure these practical issues have a lot to do with why the pro decks are so slim (the Sony decks are only 1.75" tall) and light. Looking at it from the other side of the equation, it is the audiophiles, whom the ES decks are designed for, who are often impressed by heavy components. Of course, audiophiles are not likely to transport their components all over creation.
In all of this, I think it makes sense that the pro decks are lightweights from the standpoint of practicality in everyday use by the intended clientele. However, I can't help but wonder, as I think about it more, whether that is a reflection of a poor design from a sonic standpoint.
