Mark gas
- Mar 23, 2002
Someone want to do the math on how much air needs to be moved to produce the kind of levels Dan is talking about?Ok, I'll take a shot. (I seem to be making a habit of reverse-engineering Dan's goodies. :b) (Please note that the following is nothing more than the sum of my best guesses based on reasonable numbers and doesn't account for all unknowns, such as corn-pup technolgy! )
The tools I used were Brian Steele's handy dipole response spreadsheet (Dipole.xls) and WinISD Pro. Since Dan hasn't told us much, I had to create an imaginary driver, but I made a point to tilt the parameters a decent amount toward good open-baffle response at 20Hz, just to give the benefit of the doubt:
Qes: 0.6
Qms: 20
Vas: 800 liters
Fs: 20Hz
Xmax: 99mm
Sd: 4sq. ft.
Re: 5.8 ohms
I let WinISD infer the rest of the parameters.
Here is the predicted response in a sealed box of about 20,000 liters--essentially an infinite baffle. It's about 5 dB down at 20Hz, or a little better than 87dB/W.
Next, I simulated this driver in Dipole.xls. Here is the predicted free-space response of the 24"x24" raw driver, along with the predicted IB response. It is about 21dB down at 20Hz, or about 17dB below the IB response.
Now here comes the rub. I went back to WinISD to figure out how many watts it would take to get this naked driver up to reference level at 20Hz (I forget the number, but I chose 112dB). Of course, since the dipole cancellation shaves off 17dB at 20Hz, I had to raise the IB SPL at 20Hz to 112+17=129. As you can see, WinISD predicts it will take about 15kW to get this naked driver up to 112dB on-axis at 20Hz (nearly 150mm of P-P excursion). Got half a dozen K2s?
I'm not saying until CES...Ladies and gentlemen, the unflusterable Dan Wiggins!
Dang, I'd hoped my unbridled surmising would at least serve to pry loose a few more details...
Bill
PS. Dan, with the raw excursion you're talking about here, I'm wondering if we've been on parallel tracks and you're rolling out a variation of my top-secret high-zoot suspension! Is there any way I could sign an NDA and have a peek? It sounds like your R&D is mostly finished, but I might yet be able to contribute some valuable ideas. Transducer design is my passion, and among other things, I've given extreme-excursion suspensions a good deal of thought. Email me if you're interested.
Well, all our original design notes - and the patent application itself - reference split gap. You see, our approach can do more than just 2 gaps, and there are benefits to going to more than 2... But XBL^2 is a descriptor of what it does, not how it does it. Split Gap is the topology, XBL^2 is the technology/benefit.
As far as the TC Sounds unit shown, it is a very long overhung voice coil, with extra windings out on the end. In other words, in the center of the VC it's a 2 layer unit. Then you go out towards the end, and it's a 4 layer. Then go out to the very ends, and it's a 6 layer (or effectively like that). It does give you a flat BL curve, however there are LOTS of drawbacks (enumerated above). And of course, you need to make your gap wide enough to account for the widest part of the voice coil, too...
That is why the BL is so low with so much magnet and voice coil out there - wide gap, and probably some copper shorting rings (a la the MASS units) to lower the inductance to an acceptable level, but again that widens the gap and lowers the BL...
For comparison, the Brahma has 25% MORE BL with less than 1/3rd as long of a voice coil (Estimating the displayed unit has a VC that is 3.25" long). The XXX has 50% more BL, with less than half the voice coil length.
Extreme overhung designs are inherently BL inefficient. To get decent BL you sacrifice a LOT of moving mass (added) and inductance (added). JL addressed the problems with extreme overhungs in their own way, but they still have low BLs as well (2 layer voice coil to keep inductance and moving mass in check).
Now as far as stroke goes, what about this graph (measured on our BL jig):
Yes, I truncated the measurements at 3" each way (6" peak to peak - I don't want to give the true limits out yet), and yes the BL is over 32 N/A over that entire range. It's just one of the medium throw units we have kicking around here (yes, at this point, 6" is medium throw - 2" is short throw).
Dan Wiggins
Adire AudioI can imagine why they might not need so much power.
