1. Guest,
AV Receiver video signal handling
Discussion in 'Beginners, General Questions' started by Don_K, Jun 27, 2003.
  1. Don_K
    Don_K Active Member
    Jun 15, 2002
    27
    My AV receiver... admittedly a low-end model... passes the video signal to the TV in the same "format" as the source signal. That is, a component video input requires that I have a component video input on the TV, same for composite and S-video. Is this a limitation of my receiver, or will some models "magically" route the video through a single output? My S-video DBS signal could be routed to the TV thru the component video output.
    [​IMG]
  2. Jeffrey Forner
    Jeffrey Forner Well-Known Member
    Jun 19, 1999
    1,117
    Some higher model receivers can take a composite video input and convert it into an S-Video signal. However, I know of no receiver or product that can take a composite or S-Video signal and turn it into a component signal.
    It sounds like you will need to hook up multiple video inputs to your TV to get the results you want.
  3. Don_K
    Don_K Active Member
    Jun 15, 2002
    27
    Thanks -J.Fo
    I suspected that, but was hoping for some "magic."
    Don't mind dealing with multiple inputs on the TV, but to paraphrase the wife:
    "Why can't I just watch the $%^&*() TV without this pile of remote controls?"
    [​IMG]
  4. ChrisWiggles
    ChrisWiggles Well-Known Member
    Aug 19, 2002
    4,791
    At least your fingers get SOME exercise....., and you gotta be able to move your arms to reach through all those remotes..... [​IMG]
  5. Allan Jayne
    Allan Jayne Well-Known Member
    Nov 1, 1998
    2,406
    What you need is a second VCR and a second DVD player (not necessarily the top grade). Connect these using composite or S-video directly to the TV, audio jacks too. I trust that with your receiver you are using only a small number of the TV's input banks.
    Then those family members who don't want to mess with a pile of remotes can turn things on more easily.
    They also make DVD player and VCR combos.
    Video hints:
  6. Don_K
    Don_K Active Member
    Jun 15, 2002
    27
    One solution might be to get a "programmable" remote control? Something with a graphical user interface and works kinda like a PDA? Choices are simple: I want to watch TV, I want to listen to a CD, I want to watch a DVD. Is there such a device? It could select the TV input, the AV receiver mode, and control the DVD player, Replay TV box (it controls the DBS receiver, but not without some ugly moments) -- the whole nine yards?
  7. Neil G
    Neil G Member
    Jul 1, 2003
    5
  8. Don_K
    Don_K Active Member
    Jun 15, 2002
    27
    Thanks everyone. What I'm hearing is...
    With a good programmible remote and sufficient inputs on the TV, I can dumb things down for users. That will save my marriage! [​IMG]
    Bypassing the receiver's video switching offers a potentially better picture. [​IMG] Thus the reference above about the TV having suffficient video inputs... One for each video component.
    Probably a subject for a separate thread but, I read a theory that passing the DBS output to the TV via coax rather than S-Video could give a better picture, because the TV "probably" has better video processing circuitry than the DBS receiver?
  9. Bob McElfresh
    Bob McElfresh Well-Known Member
    May 22, 1999
    5,183
    Don, for ease-of-use my suggestion is:
    - Run SVideo from EVERYTHING to your receiver. Use a cheap $20 Composite-to-SVideo converter for the old VCR.
    - Run 1 SVideo from the receiver to the TV.
    Now the system is simple to use. Just turn on the TV/receiver and use the receiver remote to switch between things. It takes care of both the audio and video switching.
    If you have component devices that you really, really want hooked up this way, run component cables directly to the TV (yes, in addition to the SVideo cables going to the receiver). For critical watching, you can take the extra step of flipping to the component input on the TV. Just be sure to put it back to 'see' the SVideo feed from the receiver for the family to use.
  10. Don_K
    Don_K Active Member
    Jun 15, 2002
    27
    Thanks Bob. Right now I only have a single S-Video on the TV... It's about 12 years old, so I'm thankful to have that one. Thus I'm stuck with using the receiver to switch the DBS, DVD, and Super VHS. I was thinking ahead a bit about the connections when I replace the TV.
  11. Agustin
    Agustin Active Member
    Jul 3, 2003
    41
    good luck man, i think its hard to handle all the conections.
    i got the same trouble like you and put the audio in the receiver and the video on the tv direct
