kameonr
- Jan 16, 2007
- Ed Keeling
My apologies if this is not the correct catagory, its part of my HT project and so I figured this is a good place to put this.
So I have asked you guys a bunch of questions here and there and done a lot of reading to help with my DIY home theater, and its getting closer and closer to completing.
I am now trying to decide on what kind of Audio package would suit my room and thought I would lean for some advice on this from you guys.
I have attached the current setup from almost the back of the room, we are looking at 11ft across and about 20ft deep with an opening to the left of the viewers once complete (nothing I can do about the opening but was thinking of closing the room in curtains that i could open and shut to get a single room feel (movie style curtains of course.
Basically we are dealing with an 110" screen and I will have two rows (one on risers (building now) and I want to have a good movie theater sound without overdoing it, as the room size is not that big to begin with.
So my question:
Could you give me suggestions on a good HTIB or a put together set that I can use for this room size without robbing a bank.
This room is for movies only if that helps....Blu-Ray movies, and regular DVD's.'
thanks in advance
So my question:
thanks in advance
