1. Guest,
Are Better cables worth it?
Discussion in 'AV Receivers' started by Antonio_B, Dec 3, 2005.
  1. Antonio_B
    Antonio_B Stunt Coordinator
    Oct 18, 2002
    187
    Right now i have a pretty good audio/video system but i would like to have even better quality.
    So do you think by upgrading a few of my audio cables would give me better sound.
    For example,i am using gauge-12 wires for the speakers,if i go with gauge-14,will it give me a clearer sound?
    I was thinking of changing also that audio cable that connect my DVD player to the receiver.What do you think?
  2. mylan
    mylan Screenwriter
    Jan 6, 2005
    1,686
    No, a 12 guage speaker wire is larger than a 14 so you'll be going in the wrong direction, regardless it will not affect the sound quality at all. As far as the audio cable from the DVD to receiver, same thing. The best thing you can do is calibrate your system.
  3. Antonio_B
    Oct 18, 2002
    187
    oh i see,ok thanks for the answer.
  4. John Garcia
    Jun 24, 1999
    11,572
    23
    NorCal
    Speaker wire will have the single least effect on your overall sound. Analog interconnects can have an influence on the sound, but if you are looking for big improvements, the speakers, sources and receiver are where your biggest improvements lie.
  5. Greg Bright
    Greg Bright Second Unit
    Feb 24, 2000
    263
    2
    Lots of folks here may believe the real title of your thread should have been "Are more expensive cables worth it?". Dicey subject that has been argued to death. It is always good to have high quality, solidly constructed inter-connects. This means not the flimsy stuff that came with your kids' cheapo DVD player. But going overboard with high-priced "magic wire" is a doubtful proposition.
