What do you mean...
"then the unused pos of the voice coil and the unused neg of the other voice coil connected"
That makes no sense.
Meaning the positive of VC1 and the negative of VC2 that were not connected to the amp were connected to each other.schan1269 said:What do you mean...
Sorry, I was merely trying to explain that I had it correctly wired this time instead of wiring it into a 1 ohm load again.. :jawdrop:schan1269 said:So in "lingo everyone understands"...
You wired it in series.
I thought all smoke detectors had a 9v backup battery. When when was the last time you replaced the batteries in them? Plus, you can't have too many batteries. I keep at least 2 years worth of batteries on hand at all times as well as extra food and water.I don't own anything that runs on a 9v battery.
No. That means it should be at reference levels. My normal listening levels with network TV with my wife in the room is -25 or 25db below reference. But that is still an arbitrary number unless you know the level the the material was recorded at.Another question, just because im curious, but when I set the volume to 0 db does that mean its at 1 watt
Going up 3db requires twice the power. To double the apparent volume requires 10 times the power. The decibel scale is logarithmic. 90db is twice as loud as 80db. 100db is twice as loud as 90db. If 1 watt of power creates 80db, then it took 10 watts to create 90db and 100 watts to create 100db. It will take 1,000 watts to create 110db. All things being equal and ignoring power compression.also every change in 3 db on the stereo means its getting twice as loud correct?
