1. Guest,
Another Toslink to Analog Question
Discussion in 'Home Theater Projects' started by digitalhecht, Jan 6, 2012.
  1. digitalhecht
    digitalhecht New Member
    Jan 6, 2012
    Hi All, HT n00b here. Actually, not HT at all, just looking for a simple solution for the man cave... After using a simple 3.5mm headphones output on previous LCD sets for years, I just bought a new Panasonic plasma that has Toslink as the only audio out option. I do not own a receiver. I'd like to be able to listen to all TV out audio (actually Xbox, PS3, and laptop) via headphones. A receiver is not in the budget. So... 1) Other than expensive digital wireless headphones (any under $200???), is there some sort of digital-analog converter/adapter out there? 2) On a related note, can you split a digital signal with a Y adapter as well? I do have a Panasonic sound bar as well. It would be convenient to split the output between the soundbar and digital headphones, if that's the only solution to question #1.) Thanks in advance! Ed
  2. Robert_J
    Robert_J Well-Known Member
    Aug 22, 2000
    8,264
    46
    Mississippi
    1. Digital to analog converter - http://www.parts-express.com/pe/showdetl.cfm?Partnumber=180-997 2. Optical splitter - http://www.parts-express.com/pe/showdetl.cfm?Partnumber=180-964
