1. Guest,
An Amp for Panasonic SA-HE200
Discussion in 'AV Receivers' started by BrianHo, May 4, 2003.
  1. BrianHo
    BrianHo Active Member
    Apr 12, 2003
    41
    Can you add an amp to this reciever? I have KVS-400 Kenwood tower speakers and i have to turn the reciever up pretty far fo it to be loud.
    Brian
  2. Kevin. W
    Kevin. W Well-Known Member
    Oct 27, 1999
    1,546
    Has the receiver been calibrated yet? Whats the sensitivity of the speakers? How far are you sitting from them? An amp would help but you have to answer the questions for a definitive answer.
    Kevin
  3. DanielM
    DanielM Well-Known Member
    Jul 5, 2002
    224
    no except for the rear center channel this receiver has no preouts
  4. JohnnyG
    JohnnyG Well-Known Member
    Dec 18, 2000
    1,523
    It doesn't matter how high you have to turn up the volume knob, as long as it doesn't distort and you get the loudness you want. During parties, I would sometimes have the volume my old H/K AVR320 pegged with no problems.
    The HE200 is really one gutsy beast. I don't think I've ever asked it for more than 3/4 of the power it has.
  5. BrianHo
    Apr 12, 2003
    41
    Well i guess turning it up to about 30 is ok then. my old Technics i had was different. The volume went up really quick on it. I never went pass 1/2 way with the same speakers.
    Brian
  6. Geoff L
    Geoff L Well-Known Member
    Dec 9, 2000
    1,702
    Where the volume knob is on any given receiver will NOT be the same even if they all had exact power spec's and are just different brands..
    The receivers pre section inside dictates how high the volume knob may have to be for a given amount of wattage output. Some receivers will be out-putting nearly full power when the knob is only at the half way point. If one continues to turn it up the amp section just begins to clip, (distortion)....not good!
    Others may increase wattage output much slower and require you to turn it up much farther to aquire the same volume in your room.
    How "effiecent your speakers are" can have a Very Large Effect on how loud they play per given watt. 85 to 89db sensitivity requires more juice to get speaker volume/spl, than say much more effiecent speakers with a rating of 90 to 95db+....
    Leave everything set the same in a system and hook a very high effecient set of speakers up,,,, and wowzer it's a whole Bunch Louder.
    So as long as your receiver is not distorting, turn it up.
    As John made mention, the 200 has a very ballsy amp section! (Pretty impressive power actually), so go ahead and turn it up as long as it stays clean....
    Many when getting a new receiver have started a thread asking about this volume knob difference. Even when aquiring a more powerful receiver.
    As far as the receivers power and adding a higher quailty seperate amp, (even if you had the preouts to make use of one) you would need about 3 times the power you have to really notice any "max volume difference".
    Better "Sound Quailty" coming from your speakers (certainly may be noticed) with better amplification of at least "equal power", but a noticable increase in spl takes at least 2-1/2 to 3 times the power increase. And then it's would be a very "Minor Increase" in volume at best, this when using your exact same speakers.
    To make something "twice as loud" requires 10 times the power, as I understand the power to spl workings..
    Cheers
