DaViD Boulet
- Feb 24, 1999
Paul,
There's nothing inherently compromised about a 46 or 50 inch 1080p monitor: screen-size isn't the issue, as you rightly say it's viewing-angle. As long as a screen is properly resolving all of the detal in in a 1080p image, then regardless of its size, as long as you sit within the sweet-spot to get a 30 degree viewing angle (around 1.5 screen widths away) you're getting a "theater wide" picture that should reveal the flaws as seen on a 100 screen viewed from 1.5 screen-widths away.
Naturally, with most small size screens, most viewers don't push their sofa or chair up that close because it doesn't mix well with room decorating etc. to have a chair facing the wall from only 6 feet away. And some folks move their chair so when the living room is a "room" the chair is far away but when they watch movies at night they slide the chair up to get their theater-wide perspective (that's a good way to do "theater wide on a budget" or when you just can't manage the logistics of a projector and screen).
Keep in mind that to get the proper viewing angle, a 3-foot wide screen should be viewed from around 5 feet back. A four foot wide screen should be viewed from about 6 feet back etc. (like you do).
But someone sitting 8 feet away from a 46" 16x9 set, for instance, is well outside the theater-wide viewing angle of about 30 degrees. I've seen many poorly mastered DVD and BDs that show their flaws at a theater-wide angle but that look sharp, clear and perfectly fine when you move back to 2 or more screen-widths away, which is one reason why there's so much confusion/debate about what discs look like on forums like this (folks rarely start the conversation with a clarification about their viewing angle).
