1. Guest,
7.1 Are you setting it up wrong?
Discussion in 'Archived Threads 2001-2004' started by John A. Casler, Oct 15, 2002.
  1. John A. Casler
    John A. Casler Well-Known Member
    Apr 29, 1999
    479
    I continue to hear people talk about setting their 7.1 systems up with Dipole/Tripole/Bipoles on the side surrounds and Direct Raditors in the Rear Surrounds.
    Does this make any sense???
    Seems to me that in a 7.1 setup, the sides are the "main" surrounds and would have the greater need for a "direct" speaker, while the rears would have little benefit from a direct since they will be firing from behind the ear.
    In Multi-channel Music and 5.1 Films, aren't the sides taking over the rears (of a 5.1) former duties and the Rears are now just for envelopment and ambience?
    I address this in my 7.1 system by having both direct and dipoles for both sides and rears, which I can play seperatly or together.
    And I think the 3' higher than listening position rule, for the sides should also "go out the window". I can still see it for the rears but if we are talking about "discrete" 5.1 converted to 7.1, I think the sides are getting the discrete information and the rears are getting the "ambience".
    Anyone have any concrete info on this? I have been all over DTS, and Dolby sites and don't see any "new suggestions" to adress this or even any definitive answers to what info is going where.
  2. Mark R. Ososkie
    Mark R. Ososkie Well-Known Member
    Aug 31, 2002
    58
    This all comes down to the way your room is set up. I have no rear walls, but i do have side walls, so i put the dipoles on the side. There is absolutely no way the dipoles could be placed behind me, so I will buy a pair of bookshelfs for my surround backs.
  3. Anthony Stephan
    Anthony Stephan Well-Known Member
    Mar 6, 2000
    97
    How are you set up to run your direct and dipole side speakers together. how do you have them wired?
  4. John Garcia
    John Garcia Well-Known Member
    Jun 24, 1999
    11,572
    23
    NorCal
    Are you using a switch that compensates for load? What receiver/amp? Parallel/series? You may run the risk of straining your amp and driving it to distortion.
    Side surrounds have ALWAYS been noted by DOLBY as being preferably bi/di to create diffused effects, not direct effects. The rears can be either monopole or bi/di.
  5. John A. Casler
    Apr 29, 1999
    479
