1. Guest,
508 acceptable noise level........
Discussion in 'Playback Devices' started by Brad Newton, Oct 10, 2003.
  1. Brad Newton
    Brad Newton Well-Known Member
    Aug 14, 2001
    387
    I just replaced my original 508 with another unit. The 1st unit had a whinning whistle kind of sound. The 2nd unit is quieter but still has kind of a low hum. To me this is not acceptable. The units I have heard in show rooms like Circuit City, my local dish vendor are very quiet. Do I have another defective unit or is this an accepted noise level with pvrs? If I choose to keep the unit, do I just have to get used to the noise?????????? [​IMG]
  2. Brian R
    Brian R Well-Known Member
    Sep 13, 2000
    64
    I have the 501 and the only time I hear any noise from it is when I first turn it on and the drive is starting. It's not really noticable unless you are listening for it. If you can hear a noise from the unit while you are watching tv that is not acceptable.
  3. Jay H
    Jay H Well-Known Member
    Mar 22, 1999
    5,678
    32
    Pittsfield, MA
    Jay
    Where are you putting the 508? I believe the fan itself is controlled by a thermometer such that you need some decent ventilation, just like with any PC or else the unit will run warmer and the fan will be on more often. I've put some larger standoffs on the bottom of my 501 and noticed the fan isn't on as much as it used to be. Of course, this doesn't help any if your fan is really loud. Like Brian says, I only hear my 501 when the unit is powered on or off as the hard drive seems to have a "park" function so you can hear an audible click.
    Jay
  4. Brad Newton
    Aug 14, 2001
    387
    I had mine placed in an entertainment center with the rest of my equipment. It had plenty of room above & to the sides & the rear was not covered. Ventilation should not have been a problem. I returned both units. I could not accept the noise. IMO I should not have been able to hear anything at my seating position, approximately 12' away. Am I wrong in thinking that way...........or is a certain level of noise customary even at that distance?
  5. Tom Weeks
    Tom Weeks Well-Known Member
    Aug 23, 2001
    73
    I have 2 508's and they are both whisper quiet. You might be having some bad luck.
