1. Guest,
4 year old RCA CRT makes "pop" discharge-like noise
Discussion in 'Displays' started by Zach Foster, Mar 4, 2007.
  1. Zach Foster
    Zach Foster Well-Known Member
    Jun 23, 2003
    59
    Hey all,
    My 27-inch RCA Flat Screen has begun exhibiting problems. Occasionally, when on, the television will make an electrical "pop" sound while simultaneously visually popping a type of "electrical interference line" on the screen. This issue lasts all of about a half second, but its frequency is beginning to increase. I've tried searching for this issue on Google but to no avail. I suspect it may have something to do with the power supply or the tube itself. Does anyone here have a clear answer to this mysterious problem?
    FYI: Here is my television in case it helps:
    http://www.amazon.com/RCA-F27TF720-T.../dp/B00006JBKG
    RCA no longer seems to have it on their own website.
  2. Dave H
    Dave H Well-Known Member
    Aug 13, 2000
    5,438
    132
    My CRT RPTV was doing this exact thing - only it was throwing off my convergence too. But, the popping has gone away (for now anyway).
    The problem is probably arching which you're experiencing - which can go away on its own, or get worse as you're experiencing. It can require tube replacement depending on the case.
  3. howitzer
    howitzer Member
    Oct 21, 2006
    11
    Open it up and blow the dust off of the HIV transformer and yoke with an air compressor. If that doesn't solve the problem, junk it.
  4. ChrisWiggles
    ChrisWiggles Well-Known Member
    Aug 19, 2002
    4,791
    How loud is the pop?
    It sounds like the HV is arcing in there.
  5. Zach Foster
    Jun 23, 2003
    59
    It's a fairly loud electrical pop. Can someone please explain arcing to me, and what I could possibly do about it?
  6. ChrisWiggles
    Aug 19, 2002
    4,791
    HV lead arcing is probably the main thing that is likely to cause a loud electrical pop type noise. Make sure your TV is turned off and unplugged for a while and consider cleaning off the HV leads they are likely coated with grime. This requires opening the TV, which is not recommended. Serious harm or death can result, the HV leads are very high voltage you don't want that arc hitting you.
  7. Parker Clack
    Jun 30, 1997
    12,217
    57
    Kansas City, MO
    Parker
    I agree with Chris. A CRT (the picture tube for the set) will act as a large capacitor (a device that holds a charge and then discharges it). The HV plug into the CRT is at the top of the tube. It has to be discharged even after unplugging your set. I wouldn't recommend this if you don't know what you are doing.
    I also agree with others here that it sounds like your CRT tube is on its way out and you way just want to look at getting a new one to replace it with. This will probably cost you a lot less in the end. You can continue to use it until it goes out altogether or take it into a shop and have them blow out the set and clean it up for you.
  8. ChrisWiggles
    Aug 19, 2002
    4,791
    Although the thing is if it's just dirt and grime on the HV leads or the HV block etc that are causing the arcing it could be a simple cleaning could resolve the problem, assuming the arc hasn't nuked any circuit boards. If that's the case it is not worth ditching the set.
