1. Guest,
4 ohm nom. and HK
Discussion in 'AV Receivers' started by Ryan Leemhuis, Mar 8, 2005.
  1. Ryan Leemhuis
    Ryan Leemhuis Well-Known Member
    Oct 1, 2002
    490
    Will a HK 335 or 435 be able to handle driving 4 ohm speakers decently loud? Anyone have any experience with this?
    If you visit the DIY forum you already know that this question would be in regards to a MTM design bookshelf I would like to build.
  2. John Garcia
    John Garcia Well-Known Member
    Jun 24, 1999
    11,572
    23
    NorCal
    Though they put out plenty of current, I don't think the H/Ks are
  3. Scott Oliver
    Scott Oliver Well-Known Member
    Aug 30, 2000
    1,159
    My easy to drive, 4 ohm, JM Reynaud speakers, that are singing away just fine with 13 watts powering them currently, shut down and blew the fuses on both channels of an HK Sig 2.1 even though I was only using 2 out of 5 channels, and I had only hit about 75-80 decibel levels. That's my experience, so I would proceed with caution.
  4. Shiu
    Shiu Well-Known Member
    Feb 18, 2003
    447
    As far as I can remember, HK has always claimed high current, but not 4 ohm stable capability. I think the 7XXX series will likely do fine but as others has said, be careful with the lower priced models such as the 335.
