MichaelOD
- Sep 25, 2003
Hi all,
I'm looking to replace my denon 2200 with either the 2910 or the 2900. To be completely honest, I like the build quality and looks of the 2900, but, I'm aware that the 2910 is basically using the same chip [FL 2310] found in the 3910 which has gotten rave reviews from the Secrets group.
So, more to the point - anyone have a chance to A+B the two. Any discernible differences? I can get the 2910 for 50 bux [CAD] cheaper than the 2900 - but I'm looking for the best picture quality for my money. I'm aware that the audio in the 2900 is superior; but I'm more concerned about the video.
What would you do if you could get either player?
For my uses, would you keep the 2200?
Thanks in advance for any responses...
Couple of other quick notes - anyone wonder why the 2900 scores [Secrets shootout] so much higher than the 2200 considering they are using the same Silicon Image chip? Does a large power supply [found in the 2900] really make that big of a difference?
