1. Guest,
$200 for mains in a 2 channel setup with no sub.
Discussion in 'Speakers' started by JohnI, Jan 13, 2012.
  1. JohnI
    JohnI Extra
    Feb 3, 2005
    23
    Looking for some mains that will be used for music only. All sorts of music. There will be NO sub so i will probably need 8's to get the bass that i need. Right? Hoping to use these for parties in my front room. The amp has not been decided, so power requirements/impedance are irrelevant. Thinking about $200 What do you guys think? Thanks!
  2. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,264
    46
    Mississippi
    For parties, you need a high SPL speaker and you can't get that retail with $200. The closest thing I would recommend is a DIY project - http://speakerdesignworks.com/NS6project_5.html
  3. JohnI
    JohnI Extra
    Feb 3, 2005
    23
    What about $250 or $300 shipped? And maybe just some 6.5"?
  4. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,264
    46
    Mississippi
    A pair of these - http://www.parts-express.com/pe/showdetl.cfm?Partnumber=245-804 or these - http://www.parts-express.com/pe/showdetl.cfm?Partnumber=248-6764 As with most, the more you spend, the better you get. These are PA / DJ speakers. Parties only. Not made for critical listening.
  5. gene c
    gene c Producer
    Aug 5, 2003
    5,838
    47
    Bay area, Ca
    Gene
    If you want more tradtional home speakers then consider BIC DV64 and DV84 http://www.amazon.com/BIC-America-Venturi-DV64-Speaker/dp/B00011KLOI/ref=sr_1_4?s=aht&ie=UTF8&qid=1326561219&sr=1-4, http://www.amazon.com/BIC-America-Venturi-DV84-Speaker/dp/B00012F7CI/ref=sr_1_9?s=aht&ie=UTF8&qid=1326561260&sr=1-9 Really on the cheap: http://www.amazon.com/Sony-SSF-7000-Floor-Standing-Speaker-Woofer/dp/B000OG4E2U/ref=sr_1_7?s=aht&ie=UTF8&qid=1326561362&sr=1-7 But again, not exactly high quality sound but great bang for the buck if you want to make a lot a noise. But also check the Fry's adds in your area. They've had the Infinity P362's for under $300 ($199 a couple of times) per pair. And the Polk RTi8's for $199 recently. These really are pretty good sounding speakers. Also the Polk Monitors from newegg.com http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100006922%20600030002&IsNodeId=1&Description=polk%20monitor&name=Floorstanding%20Speakers&Order=BESTMATCH Maybe craigslist?
  6. JohnI
    JohnI Extra
    Feb 3, 2005
    23
    Oh man, guys. When i said party you thought i meant a mini rave or whole house party. I meant like 10-20 people dancing in my living room, which is seriously like 15x20 ft. Sound quality and looks is important. PA speakers won't do. What about this sub..... http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-633 with one these bookshelves....... http://www.htd.com/Products/level-two-speakers/Level-TWO-Bookshelf-Speakers http://www.svsound.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=20&category_id=11&vmcchk=1&option=com_virtuemart&Itemid=108 http://www.aperionaudio.com/product/Intimus-4B-Satellite-Speaker,113,20,261.aspx Any other suggestions? I live right by Aperion by the way.
  7. gene c
    gene c Producer
    Aug 5, 2003
    5,838
    47
    Bay area, Ca
    Gene
    Well now you've completely changed direction. :) That sub is decent for the price. And I've never seen it that low before. Usually it's on-sale for $129 The SVS and Aperion speakers are very good, but so are the Infinity and Polk's I linked to. I'd take the SVS's over the Aperions because they are much larger. 6" vs. 4". But the number of good bookshelves for $250 is staggering.
