Mike Thomass
- Aug 11, 2003
btw, bondo is fantastic it appears
Originally Posted by Robert_J
1/2" polyfil is no where close to 1 pound per cubic foot. You have to stuff by the handful to get that much in the box. Just don't impede the air flow into the port....Really, you don't need that much. That enclosure was designed to work without stuffing. Go to Wal-Mart and get some open cell, egg crate foam (mattress pad) and cut it to fit the sides and behind each driver. That will absorb the higher frequencies of the rear wave and lessen the reflection.
Bondo is great about fixing any mistake. One of these days I'll get brave and fix the hail damage on my 15 year old car.
My solder has flux in it. Probably Radio Shack brand. I'll check the part number when I go through the garage next time.
Re is the measure of resistance. DC current is applied. Impedance is when an AC current (that's what makes the sound) is sent through the speaker. The impedance varies by frequency and the average is 8 ohms.
I'm a huge Pioneer fan. I'm sorry if I am repeating myself but I listen to a VSX-4800 every day during work. Bought from Wal-Mart in 1992. I've run nothing but Pioneer head units in my car since the 1980's with the exception of a Sony because I needed a shallow mounting depth in one car. My home theater receiver is a VSX-1014 and it does fine with 4 ohm speakers.
One thing about all of the speakers designed by Wayne J., they are easy on the amps. No wild impedance swings. His DHT design is probably the lowest impedance of all and that's what I need to finish building.
You can go with an external amp if needed. Maybe adding a Behringer A-500 to run the D8's and use the receiver's amp section for all of the rest.
I Googled pioneer vsx-1020 4 ohm speakers and found a lot of information. A lot of people run their Pioneer at 4 ohms without any problem. Just don't put anything on top of the receiver so the hot air can escape.
Originally Posted by Mike Thomass
I just didn't want to burn up your new receiver with those 4 ohm speakers.
Many receivers that aren't certified for 4 ohm can drive them anyway, but I'm sure it would usually be the higher priced models. I just have my doubts about the 1020's ability to do so long term. The 1014, yes. The 1020, I don't know. They're packing an awfull lot of new things into these newer receivers and something has to give. Usually it's the amp section.
I'm not sure of any tell-tale signs that a particular receiver would work with 4 ohm speakers. I just look at all the data and let common sense take over. I might try it with the 1120 myself but I wouldn't feel comportable recommending it for someone else. The 1120 does have a better amplifier in it.
Maybe you should start another thread in the receivers forum. Pick a price point and most needed features. Refurbished or a good used one might be your best bet. As an example, someone on Audiogon has a 92txh for $350/best offer. I was eyeing that myself but picked up an Integra instead.
Onkyo has a few 4 ohm receivers, I think starting with the 7XX models. As I understand it, most 4 ohm receivers, when set to 4 ohms, simply reduce the power output to help protect it. I've often heard you should leave it at the 8 ohm setting anyway.
Anyway, finish the speakers first, then worry about the receiver.
Edit: If others at another forum are doing it then that's the kind of re-assurance I was hoping to find. But that still sounds like a lot to ask of that receiver.
