1. Guest,
100W @ 6 Ohm vs 100W @ 8 Ohm
Discussion in 'AV Receivers' started by TheseusOfAthens, Aug 30, 2013.
  1. TheseusOfAthens
    TheseusOfAthens New User
    Aug 30, 2013
    2
    Tyler
    Hi,
    I'm looking to upgrade from a Kenwood VR-401 5.1 A/V Receiver to something more modern. I've
    been putting an unnatural amount of research into the latest receivers and I narrowed my selection
    down to the Sony STR-DN1040.
    This receiver seems to be perfect for me with 7.1 channels, built-in wifi, Airplay, plenty of HDMIs, and
    a beautiful on-screen display. The only problem is that the official specs rate it at 165W x 7 @ 8 ohms
    1kHz 0.9% THD 1ch. driven while the Kenwood is listed as 100W x 5 @ 8 ohms 20- 20kHz 0.7% THD
    2ch.
    My 100W 8 Ohm speakers sound beautiful paired with the Kenwood receiver so loosing sound quality
    when I upgrade is a HUGE con.
    I downloaded the Sony STR-DN1040 manual and it said that the receiver can also run at 100W x 7 @
    6 ohms 20- 20kHz 0.9% THD 2ch. I know running this would be better given the frequency range.
    The BIG question here is wether or not there's a difference in sound quality running in the 6 Ohm
    range vs the 8 Ohm range.
    Thanks for the help, hopefully this is going to give me some peace of mind.
  2. schan1269
    schan1269 HTF Expert
    Jul 4, 2012
    17,037
    894
    Chicago-ish/NW Indiana
    Sam
    The "ohm range" is not a user selectable thing. It is based on the speakers.
    Also ohm load is not a constant. It could be 4ohm at 150hz and 12ohm at 10k.
  3. TheseusOfAthens
    Aug 30, 2013
    2
    Tyler
    I guess I should rephrase my question.
    Does a receiver that uses the 100W @ 8 Ohms spec sound better than a receiver using the 100W @ 6 Ohms spec?
    Is the difference in sound quality so minute that it doesn't make a difference?
  4. schan1269
    Jul 4, 2012
    17,037
    894
    Sam
    How a manufacture calculates(or, misrepresents) their power is meaningless in terms of sound quality. It is nothing more than how much power is there.
    Your speakers themselves determine 90% of everything sound related.
    It also helps to know how power and volume work. As "total power" is typically meaningless.
    A speaker that produces 92db of sound at 1 watt...
    Requires around 1/8th of 1 watt to produce enough volume to hear it(typical general listening is done around 85db)
    "Rocking out" is around 95 db. So you are sending 2 watts to your speakers.
    Annoying your neighbors and making yourself go deaf is 100db. Which would require around 8 watts.
    Adjust those numbers as you need for various inefficient speakers(as low as 85db) and super efficient speakers(95db and above).
  5. gene c
    gene c Well-Known Member
    Aug 5, 2003
    5,837
    46
    Bay area, Ca
    Gene
    Bottom line...how a manufacturer decides to rate their receivers power outpt (4 ohm, 6 ohm, 8 ohm, whatever) has nothing to do with how your speakers will sound.
    A receivers SQ has more to do with it's DAC's, DSP chip and the quality of it's amp section (as well as an room crrection software). Nothing wrong with vintage gear. I just sold an Adcom GFR-700. Massive power supply (168 x 5 @ 8 ohms) and very sweet sounding but very basic by todays standards and difficult to live with. But I miss it already.
  6. Mr645
    Mr645 Well-Known Member
    Dec 23, 2011
    216
    2
    Boca Raton, Florida
    Jon
    Botton line is that neither receiver will come close to delivering 100 wpc under normal conditions.
    Theoretically the amp that can deliver 100 wpc into 8 ohm will be slightly more powerful then one that can only deliver 100 watts into a 6 ohm load. However power has little to do with sound quality.
    Manufacturers do things like rate it at 1khz instead of a full 20-20k range, or allow up to .9% THD in this case instead of a typical .01%
    100 wpc 2 channels driven into 6 ohm at 1khz is like measuring the top speed of a car, going down a hill, with a strong tail wind
    I am not familiar with the Sony STR-DN1040 in any way, but I am guessing that at $600 they seem to be selling for, you can do a lot better.
