New Posts  All Forums:Forum Nav:
65 INCH LCD??
post #1 of 10
Thread Starter
i have a 65" Mits. DLP.   But the rainbow effect really is distracting.   i watch a LOT of 4x3 movies, so burn-in scares me with plasma.  Basically that leaves me thinking about an LCD for my 20 foot living room.  Hve been looking for a 65 inch LCD, and have heard that they might be coming.....does anyone know for sure if we might be seeing them before Christmas of this year.  Sharp used to have 'em....but not readily available now.
  Thanks for the help.
Gear mentioned in this thread:
Sony BRAVIA W-Series KDL65W5100 65-Inch 1080p 120Hz LCD TV, Black
post #2 of 10
You could always pick up a 70" Sony, if you don't mind the $20 000 price tag.
post #3 of 10
The prices for LCDs over 52" is outrageous. That's why people like me are buying DLPs. It's the only affordable way to get a screen over 52". You can probably get a projector cheaper than a big screen LCD.................
Good luck!
post #4 of 10
You can definitely get a projector cheaper. I LOVE mine. But it depends on your room.
post #5 of 10
Bob--How old is your current Mitsubishi?  You might want to check out the new crop (737/837 series) with 120 Hz feature; user feedback indicates that rainbow effect is rendered all but unnoticeable.
post #6 of 10
There are still some of the Samsung LED DLP sets available and they don't have a color wheel, so no expensive bulb to replace or rainbow effect. I haven't seen them myself, but  most of the reviews I've seen claim the Samsungs have better picture quality than the Mits DLPs.
post #7 of 10
I can't for the life of me understand why Samsung chose to exit the DLP market, given the uniqueness of their LED-based design.  I have seen one on display (my local Best Buy still has their 60" floor model) but my eye can't tell any difference.
post #8 of 10
I suspect Samsung didn't like the idea of having 3 different technologies competing for the same market. I also suspect that the profit margin on DLP is pretty thin in comparison to LCD and plasma.
post #9 of 10
You probably already know about Sony's new 65 inch LCD set for $4,999?  Check out the Sony style store.  I went to see it:  it's beautiful.  Sonystyle.com
post #10 of 10
I heard that Sharp got out of the big LCD's as the fallout of a lawsuit that they lost.  Patent infringement, or something, I don't remember the details, except for the fact that before that happened, we ended up with three of 'em at work!
I have heard that the newer plasmas, if you don't abuse them, aren't going to burn in any short-term measurements.  And someone gave me a value -- full white not to exceed... ### NITS (which is often the unit of brightness given with PC monitors.)  Unfortunately, I can't remember what that number was.  But I think it was a reasonable number -- under 150-200 NITS -- my PC monitor is tuned to about 145 NITS (as I recall,) and it's painfully bright.
Leo
  Return Home
