I am planning to use my loft in my new purchased home as a dedicated home theater. Howevver, before I setup my equipment, I would like to make the drywalls to be soundproofed. I was thinking of taking down the drywall and add some soundproof materials so that less sound can be emitted to the outside. I went to Home Depot and I was told to use those sheet of styrofoams in between the studs and then use those sound insulation sheet before putting back the drywall or maybe even replace the drywall with those Quietrock drywall....not sure if this is money well spent. Or maybe just use the Quietrock all the way without even bother to spend money on those styrofoam and sound insulation sheet. Can anyone share their knowledge on this? I am trying to get the most optimal result with the best bang for the buck.
Another thought is to use a professional service to install it and wonder if it will cost a lot more than do it yourself. i am a pretty technical guy so as long as I have the guide, I should be able to do it myself.
Thanks!
Thanks!
