Just purchased a 50" Samsung Plasma, Boston Acustic Sound bar and Sub with a Samsung Blue ray that hooks up to the wireless router to rent movies over the internet. I also have a Wii and Xbox hooked up.
I purchased this at Best Buy through Magnolia Home Theateer. When they installed the stull they used HDMI for everything. The unit is hooked up to HD Cablevision and the cablevision remove woprked all TV functions.
My probem initially was that the cable remote did not move the volume on the sound bar only the TV speaker volume. After 3 visits from the Geek Squad a manager just left my house and he was able to program the sound bar to the remote. My problem is that since he used the "external" speaker function every time i cahnge the volume a large blue box 15" long and 8" high pop up and says not availible with a yellow triangle. It stays in place for 5 seconds after the volume is released on the remote.
The suggestion he made was to connect the unit with RCA cables instead of HDMI. He said that wouyld work. i asked about picture quality and he said if would drop a little. i do not want to drop quality. What can i do? I am considering returning the whole thing at this point if it cannot be fixed
Thanks for the help.
Jeff
Jeff
