Okay, here's my problem.
I bought a crappy panasonic home theater in a box (DVD/Receiver, Speaker, Sub) set several years back.
I want to run 5.1 surround sound from my Blu-Ray, Satellite Receiver, and XBOX to the through the home theater system in a box. Problem is, it only has 1 digital optical in plug. I tried running all the systems with HDMI cables through my Panasonic Viera TV, and then using an optical cable from the TV to the home theater system, but I found out my TV will convert the sound to 2 channels.
Eventually, I want to purchase a real home theater system, but I dont want to blow alot of money on it right now. I would like to start by buying a receiver, but most receivers I looked does not have an digital optical out plug and does not have a good way of transferring the digital sound to the home theater system in a box.
Does anyone have any suggestions on what I should do? Your suggestion would be appreciated. I also looked at getting a toslink optical switch, but my xbox does not have an optical cable.
Thanks!
Thanks!
